Exhaust pipe heat
Jeff5015
First Name: Jeff
Last Name: Schroeder
Exhaust pipe heat
Post by Jeff5015 » Sat Jul 13, 2019 7:04 pm
Do any of you think there would be a problem if I wrapped the exhaust pipe (with fiberglass wrap) to cut down on the heat coming up through the floorboards? It's a '16 Touring. Thanks,
Jeff in Florida
1916 Touring
Phillip
First Name: Phillip
Last Name: Lee
* REQUIRED* Type and Year of Model Ts owned: 1927 Model T Roadster Pickup
Re: Exhaust pipe heat
Post by Phillip » Sat Jul 13, 2019 7:09 pm
I wrapped my exhaust pipe just under the floor board on my 27 Roadster Pickup and have had no issue. The floor is cooler. It is lots easier to remove the exhaust to wrap it.
Phillip
paddy1998
Last Name: Delaney
Post by paddy1998 » Sat Jul 13, 2019 7:10 pm
I just did exactly the same thing using titanium wrap (the titanium has a higher max temp and is easier to install).
It smokes pretty good the first time it heats up so just be aware of that.
As far as whether it works, I don't know yet.
principal6553
First Name: Rick
Last Name: Ross
Post by principal6553 » Sat Jul 13, 2019 7:27 pm
Mine is wrapped. Smoked for a few minutes and no issues since. Good luck!
Jeff5015
First Name: Jeff
Post by Jeff5015 » Sun Jul 14, 2019 10:14 am
Thanks guys.
1916 Touring
Roffe
First Name: Rolf
Last Name: Oehman
Post by Roffe » Sun Jul 14, 2019 11:45 am
Or you could use an aluminium shield mounted with spacers and wood screws under the floorboards. Two pieces . One for each floorboard.
John.Zibell
Last Name: Zibell
Post by John.Zibell » Sun Jul 14, 2019 4:08 pm
I have wrapped my stainless pipe with exhaust wrap. I wouldn't wrap regular steel as the wrap can hold moisture increasing the rust rate of the pipe. I also stapled automotive insulation to the bottom side of my floor boards. Doing both make a big difference.
1926 Tudor
Mountainrider
First Name: Neil
Last Name: Haywood
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Post by Mountainrider » Sun Jul 14, 2019 5:51 pm
I did both. Exhaust pipe wrap and I made a heat shield
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Wed Jul 17, 2019 9:16 pm
I used a piece of 4" flexible metal dryer hose cut in half to fit over the pipe as a heat shield. It was easy to form and wire in place.
1912 Torpedo Roadster
Roffe
First Name: Rolf
Last Name: Oehman
Post by Roffe » Sun Jul 21, 2019 1:06 pm
Ps:Sorry Had to repost this due to the website transfer the picture got lost.
Mountainrider
First Name: Neil
Last Name: Haywood
Post by Mountainrider » Sun Jul 21, 2019 2:16 pm
Repost of picture
