Sediment Bowl Year(s) ID
GEmering
First Name: Gene
Last Name: Emering
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
Post by GEmering » Sat Jul 13, 2019 9:54 pm
Can someone more knowledgable than I am please identify this sediment bowl.
Looks like the 1910 - 11 style?
sediment bulb 2.jpeg (15.59 KiB) Viewed 5493 times
sediment bulb 1 .jpeg (15.74 KiB) Viewed 5493 times
Thank you,
Gene
Gene Emering
Newton, New Jersey
Re: Sediment Bowl Year(s) ID
Post by Allan » Sat Jul 13, 2019 11:57 pm
The drain petcock with the screw in retainer is an indicator of an early piece. They can work loose, and if fitted to the pan, one can quickly lose a lot of oil.
GEmering
First Name: Gene
Last Name: Emering
Post by GEmering » Sun Jul 14, 2019 8:44 am
Thanks Allan.
It's not one that I am going to install on a car.
Can anyone narrow down the years of use?
Best,
Gene
Gene Emering
Newton, New Jersey
Post by DanTreace » Sun Jul 14, 2019 11:12 am
Doesn't seem like Ford style.
This link has 1911-12 torpedo bulb, the cigar shaped one, and the typical '09-'10 screw in brass one, the valve body with lever is separate piece.
http://www.mtfca.com/discus/messages/29 ... 1183685464
Yours seems to be iron? Or is it brass bulb? The hex fitting below the threads is interesting.
Don't know enough on early Fords if this is a transition to the 1911, which is riveted to the gas tank, without a built in lever shutoff like your part.
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sun Jul 14, 2019 4:05 pm
Probably non-Ford. Pipe thread into the tank was common in the industry.
Last Name: House
Post by George House » Sun Jul 14, 2019 4:16 pm
I don’t think it’s Ford either. The cylindrical cast iron housing where the bronze valve operates gives it away. Also, the early sediment bulbs were cast bronze and didn’t have the hex fitting for a wrench.
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Jul 14, 2019 4:32 pm
Without digging through pics is looks the same or similar to what ford used pre-t. Actually, pre-NRS. Pretty sure they just bought them off the shelf somewhere, it could work very well for an A, B, C, and F. It would be worth some digging on the EFR site. As others said , it would work very well on many 1900-07 or 8ish autos.
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Jul 14, 2019 4:46 pm
This is a model F ford sediment bulb. I made one of these tanks years ago, but forget which . I think this is rob heyens baby now. If you want to sell, I think I have a friend that would buy it.
Post by DanTreace » Sun Jul 14, 2019 4:49 pm
This photo from Parts and Price list of the N,R,S Fords. Similar shape of round bulb, but no shut off lever built-in.
N,R,S sediment bulb
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Mon Jul 15, 2019 9:04 pm
Today I needed to move the 09 and noticed that the sediment bowl is round and about the size of a large walnut but I didn't see a shut off on it. It is mounted outside the frame and no room to reach between it and the frame so it will need another look on a cooler day and no way for me to know if it is correct for an 09. Another item I had not given any thought to before this post came up.
Post by DanTreace » Mon Jul 15, 2019 9:12 pm
Bob
A 1909 sediment bulb, taken at show, award winner. The shut off valve is a threaded on separate item, same as the petcock. All brass.
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Mon Jul 15, 2019 9:59 pm
After seeing Dans picture it made me go out and get a picture of what I have. Other than the newer style shut off and fuel filter it looks the same as Dans picture. Yes mine is brass too.
