I thought YOU put gas in it.
Post by Dollisdad » Sat Mar 07, 2026 11:44 am
Re: I thought YOU put gas in it.
Post by Dollisdad » Sat Mar 07, 2026 11:45 am
Post by Dollisdad » Sat Mar 07, 2026 11:46 am
Post by Dollisdad » Sat Mar 07, 2026 11:47 am
Daisy Mae
First Name: Kurt
Last Name: Andersson
Board Member Since: 2024
Post by Daisy Mae » Sat Mar 07, 2026 8:36 pm
Imagination running wild with this one...
Grab the fluted rim, turn the outer shell winding an internal clock spring, push the center button...voila auto crank
Anyone??
Post by TXGOAT2 » Sat Mar 07, 2026 9:05 pm
Certainly a good guess. Old John Deere tractors were started by using the flywheel rim as a crank. I believe they had finger holds cast into the inner flywheel rim, like a steering wheel... or like that starter.
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Mon Mar 09, 2026 7:55 am
The starter above is a Stewart compressed air starter. The air air storage tank is visible under the car.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Mon Mar 09, 2026 9:37 am
Thank you Dan!
So a little more digging answered my next question as to pump method. VERY cool, certainly better than a belt driven pump! A starter AND on board compressed air...what a thing to have in the day.
Model T Ford Forum: Accessory Air Compressor -- Stewart Air Starter https://share.google/MPqi430pKZNLbO4Sq
Last Name: House
Post by George House » Mon Mar 09, 2026 10:45 am
My favorite is the 8th from the bottom 1913 cutoff touring hauling milk. Sure looks very ‘used’. I hope it’s paid for. But the photo reveals fonts were indeed lost ‘back in the day’. Reminder: tighten the font thumb nut before this season’s tours….
