Ring and pinion gears
Oldrusty26
First Name: Travis
Last Name: Melnick
* REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT 25 runabout many misc projects
Board Member Since: 2012
Post by Oldrusty26 » Mon Mar 09, 2026 3:26 pm
Hello all !! Are the ring and pinion gears the same between the small drum and the large drum
Re: Ring and pinion gears
Post by RajoRacer » Mon Mar 09, 2026 3:46 pm
Sure are !
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Mon Mar 09, 2026 3:48 pm
Old Rusty,
The Ford ring and pinion is interchangeable 1909-27.
Ruckstell made special rings and pinions that are not interchangeable with the Ford ones.
The differential carrier and spider gears changed through the years but are interchangeable in sets.
Mike
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Mon Mar 09, 2026 6:18 pm
Thanks Mr Silbert !! Appreciate your help. Working in a 25 and the ring gear is toasty
Post by speedytinc » Mon Mar 09, 2026 6:36 pm
Old Rusty,
Mike
Well........ Not exactly.
There are ring & pinion gear sets produced with a slightly different tooth angle.
They are marked with about an 1/8" round dimple on both gears. They are not to be mixed with non dimple marked gears.
I believe there was a service bulletin warning to this effect.
Last Name: van Ekeren
Post by Kerry » Mon Mar 09, 2026 6:46 pm
I haven't come across any of the late USA Ts having the dimple marked gears but have in the Canadian Ts, Canadian service bulletin in 1923 shows them as new design drive gear and pinion.
Post by speedytinc » Mon Mar 09, 2026 6:55 pm
I have several sets & loose individual gears I have acquired over the years.
I don't know how they made their way to the swap meets. I acquired them in the USA.
I know enough not to mix em from a service bulletin. Something to be aware of.
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Mon Mar 09, 2026 7:22 pm
This is the Service Bulletin in question:
I have tried to match the ones that I have together in sets and identify them as such.
Post by Allan » Mon Mar 09, 2026 7:28 pm
My mum taught me to avoid anything with spots on. Now you guys say it's OK in given circumstances!
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Mar 10, 2026 8:21 am
Not being a Canadian car guy I have never seen spotted ring gears or heard of them.
I also have never seen or read Canadian service bulletins.
I did read the American service bulletins cover to cover as a kid 50 years ago, what was I thinking.
Maybe I live too far from the border.
There is always something new to learn about the Model T Ford.
Mike
