No sick cow?
First Name: Dallas
Last Name: Landers
No sick cow?
Post by Dallas Landers » Tue Jul 16, 2019 11:12 am
Had horn apart. Cleaned it, bench tested it. Cleaned switch, tested wires, power to horn is good. Cleaned mounts on the head and water inletof rust and paint. If I run a ground wire to the body of the horn, I get a loud sick cow sound. Why is it not grounding through mounts?
Ruxstel24
Last Name: Hanlon
Re: No sick cow?
Post by Ruxstel24 » Tue Jul 16, 2019 11:50 am
Dallas, did you take the horn off the bracket and clean there also ?
Should ground through the bracket, so something is dirty between the path...
Mooooo !!
