Radiator rebuild progress. Almost done.
Jeff
First Name: Jeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by Jeff » Fri Jan 18, 2019 1:17 am
I took a break from working on the website today and stopped by the radiator repair shop to check on progress. The core arrived yesterday and the owner, Randy, was assembling it and he let me watch the whole process. There really is an art to doing this right, and Randy is an artist. He’s been rebuilding radiators with his dad for 50 years.
The core came from a shop owner in Oakland who worked with Randy’s dad for decades. He has all the jigs to build literally any radiator core. It took one day to turn my core out after he got the exact specs from Randy.
What a great rig for holding this awkward unit!
Hole for the overflow had to be drilled and then soldered in place
The bottom cap was soldered in place
The inlet and outlet fittings were added next
And finally the whole unit tested for leaks. No more than 5-10 PSI. Success!
Tomorrow it gets painted and I put it back in the car just in time for our Polar Bear tour Saturday morning. This is cutting it close!
Jeff
"The trick to creativity is knowing how to hide your sources..." Albert Einstein
1921 Model T Touring, 1930 Model A Roadster
Voltage Regulators, Starter & Generator Repair & Parts manufacturing
www.modeltregulators.com
www.modeltstarters.com
Last Name: van Ekeren
Re: Radiator rebuild progress. Almost done.
Post by Kerry » Fri Jan 18, 2019 1:40 am
Boy! :o what a big radiator for your T Jeff, a big piece of card board to get that puppy to run warm for ya! :D
Post by Mark Gregush » Fri Jan 18, 2019 2:22 am
I don't see a baffle? Nice work.
Jeff
First Name: Jeff
Post by Jeff » Fri Jan 18, 2019 8:57 am
Aha!
Jeff
Post by Rich Eagle » Fri Jan 18, 2019 10:41 am
You are fortunate to find folks who can do that. We have lost some of our repairmen lately.
Have fun on your tour.
Post by Allan » Sat Jan 19, 2019 7:39 am
An interesting point in fitting the bottom outlet after the tank is fitted. My man always fits the outlet to the tank first, and then fits the unit to the core. He does it this way so there is less chance of the extra heat used on the cast outlet upsetting the work he would otherwise have already done if the tank was fitted first. I guess its all up to the individual craftsman. We have lost two locals, and now I have to drive 30 miles through the city to find anyone with the skills they used.
Nice work on your radiator.
Post by Wayne Sheldon » Sat Jan 19, 2019 5:11 pm
I wish I was a bit closer to your part of the state! I may need to go that route for a brass radiator.
AdminJeff
Post by AdminJeff » Sat Jan 19, 2019 10:15 pm
He’s trying to sell his bldg and get out of the biz so I jumped on it before I couldn’t.
Post by Wayne Sheldon » Sun Jan 20, 2019 12:35 am
I can't say as I would blame him. I actually built a radiator myself about forty years ago for one of my antiques. It is pretty tough work.
Post by Kerry » Sun Jan 20, 2019 2:03 am
It's a trade that is not good for your health long term, although regulated in Australia by Work Safe with blood tests and workshop vents and fume exstractors etc, you are still working with heavy metal, tin and lead poisioning, acid fumes from flux's, cleaners and hot tub caustic soda's.
My old man worked his radiator service with out all the BS in regulations and died at 86, my younger brother doing it by the book is now on his second run of chemo for cancer in 4 years trying to get a few more years out of life, he's just turned 60.
His argument with the powers to be was why pull all the toxins up to fan exstractors so it's air born even longer, let it fall to the floor and stay there. But the powers to be wouldn't see that logic.
Mindless Automaton
First Name: Kep
Last Name: Kerensky
* REQUIRED* Type and Year of Model Ts owned: 23 truck, 26 bug
Board Member Since: 2011
Post by Mindless Automaton » Tue Jan 22, 2019 3:46 pm
Kerry, the logical thing to do is put the extractors on the floor.
Post by Kerry » Tue Jan 22, 2019 5:59 pm
True Kep, but we are dealing with the intelligance of over educated nit-wits working in government departments, logic? why I even had one ask once why water in an open drain wont run up hill :D
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Tue Jan 22, 2019 6:39 pm
Yeah, I believe they're the ones who put a screen door on a submarine...
George N Lake Ozark
First Name: George P
Last Name: Clipner
Post by George N Lake Ozark » Wed Jan 23, 2019 12:04 am
What kind of paint does he recommend ??
AdminJeff
Post by AdminJeff » Wed Jan 23, 2019 1:09 am
He uses rattle can rustoleum. He has his entire career on all radiators he rebuilds. This isn’t a 500hp racecar... it’s a 100 yr old, 20hp model T. I have to alway keep that in mind when I try and overthink working on this car. Put down the precision instruments I’m so used to using on my 911 racecar and grab the sledgehammer and the welder! unless you’re inside the motor of course.
Jeff
