An evening drive in Rochester
Mark Osterman
Topic author - Posts: 1014
- Last Name: Osterman
France and I on an evening drive in Rochester, NY. A nice view of the city from the Ford Street Bridge.
https://www.instagram.com/p/B0KZ62NATFy ... icd95e9usv
Mark Osterman
Re: An evening drive in Rochester
Well, the real question is: did you get stopped at the light or did you simply stop recording incriminating evidence??
Novice
- First Name: Jim
- Last Name: Davis
I don't think the T can stop that fast ?
Mark Osterman
I went through that yellow light ok.
Duey_C
- First Name: Duane
- Last Name: Cooley
Way too short Mark but sweet! I could even hear your T running! Sounds good!
Lipping off a bit here, you have a muffler that can be heard like the '18 here.
I took 2 baffles out.
JP_noonan
- Last Name: Noonan
- * REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
Hey Mark, is the chattering you encountered earlier still gone after the oil change?
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
Mark Osterman
Even though it seems really close I was ok at that light. It’s a long duration at that spot and not a cross street, just a yield one coming from the right and no one was there. Driving in the city is a very different experience than out in the country in a model T, you really have to be on your toes. As far as the chatter, yes I would say it’s 95 % cured with the oil viscosity change.
