Radial Tires
Kuhner
Topic author - Posts: 61
- First Name: Greg
- Last Name: Kuhnash
- * REQUIRED* Type and Year of Model Ts owned: 1917, 1921 touring 1927 RPU
- Board Member Since: 2006
Radial Tires
Just seen an ad in the new AACA mag. Coker tire now has 440/450 R21 tires for sale. I’ll be needing tires soon, but just doesn’t seem right to have radials on the old truck.
The brand is American Classic, not listed on their site yet.
“I don’t like nice people. I like tough, honest people”. - Woody Hayes
Chris Barker
- First Name: Chris
- Last Name: Barker
Re: Radial Tires
I wondered what made you think they are radials but they are on the site as 'Bias Look Radials' despite the inch width sizing
Radials are almost always marked with width in mm, so tI would have expected 115 x 21
Kuhner
- First Name: Greg
Re: Radial Tires
Here is the advertisement
FreighTer Jim
- Last Name: Jarzabek
- Board Member Since: 2008
Rich Bingham
- First Name: Rich
- Last Name: Bingham
Re: Radial Tires
Not to say they might run great on a Model A or Model T. My personal experience has been that radials have not been a good thing on some mid-30s cars with more sophisticated suspension systems that were designed for bias-ply tires. Handling became erratic and "mushy". I eagerly await user reviews.
"Get a horse !"
- Last Name: van Ekeren
Re: Radial Tires
I'm wondering what the alignment specs would be? might be some serious axle bending to get a zero camber like a modern radial.
Philip
- First Name: Philip
- Last Name: Thompson
Re: Radial Tires
I bet they are awesome. But expensive. Philip
Bill Dizer
- First Name: Bill
- Last Name: Dizer
- Board Member Since: 2014
Re: Radial Tires
In the past, when we put radial tires on older cars, especially Chrysler products, the camber stayed the same, but we added a good bit more caster, to stop wandering, and give more "feel" to the steering. It really helps! You need to keep caster even on both sides, or you will get a "pull" to the side with the least negative caster. Not related to a camber pull.
In other words, if you add radials, you may well need to add positive caster to the axle to get it to steer like it used to.
Re: Radial Tires
Now we have USA made tyres for the improved 26-7 T's, let's hope Coker can do the same deal for 30 x 3.5 cinchers. I'm not holding my breath!
D Stroud
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
Re: Radial Tires
Kerry, why would radials need zero camber? I would think any tire/axle design would need camber to counter act the inner and outer diameter of the turning radius. What difference would radial tires make? Just curious. Dave
1925 mostly original coupe.
