Scat Rods 2T7000
Last Name: Hatch
Scat Rods 2T7000
Post by Dan Hatch » Wed Jul 31, 2019 7:42 pm
Has anyone used these rods? Are they the standard T rod? I would like to see a pic of one. Catalog says they are 1.250 on the rod size. That is T crank size. Anyone have info? Thanks Dan
Last Name: van Ekeren
Re: Scat Rods 2T7000
Post by Kerry » Wed Jul 31, 2019 8:48 pm
Can't help you on the rods but, Ford cranks are 1.248" and now the scats are the same. .002" oil clearance.
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Post by tman1913 » Wed Jul 31, 2019 10:04 pm
Standard Ford crank was 1.2485" for .0015" clearance
Scat crank is the same Dia.
The Scat rod is H beam construction standard model T length with bushing for a model T piston wrist pin. The wrist pin is full floating (no wrist pin bolt) so a button is used or you can contact Chaffins for a set of Eggs pistons with a snap ring. hope that answer some questions..
Post by Kerry » Wed Jul 31, 2019 11:12 pm
I wish that was the specs on the new scats Mike, the last 2 new scats I fitted and with shell bearing rods came in at 1.248" and giving the .002" in oil clearance. The earlier scats I have fitted came in at 1.250" that wasn't a problem as I do my own rod pouring and machining and at .0015" clearance. The old general specifacations for the Ford crank is listed at just the 1.248" .
modernbeat
First Name: Jason
Last Name: McDaniel
* REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
Post by modernbeat » Thu Aug 01, 2019 12:02 am
Dan, I called and spoke to Scat about those rods. The part number you are asking about is for Babbitt, not a shell bearing. They make a rod with a Model A journal that has a shell bearing. But the Model T replacement rod is just a heavy duty (racing/performance) Babbitt rod. And they don't come with Babbitt, so you have to have it done.
Jason McDaniel
Last Name: Hatch
Post by Dan Hatch » Thu Aug 01, 2019 8:49 am
Is this the rod that Snyder sells? Dan
tman1913
Last Name: Bender
Post by tman1913 » Thu Aug 01, 2019 9:50 am
Dan
I don't have a current parts book from Synders so I don't know if they sell the Scat rod your asking about. Guess you should call them. The part number is indeed a Scat rod as Jason has posted
Kerry. Don't know what to say about your cranks but I have five of Scats T cranks in the shop today. All measured 1.2485" +/- .0002". My info on model t cranks dia is 1.248 to 1.249. New old stock cranks have all measured 1.2485". Maybe just my luck. Yes the early Scats measured 1.250". Oh well we can make them work lol.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Thu Aug 01, 2019 10:58 am
The finished diameter of the Ford T crankshaft is 1.248” to 1.249” according to the Ford Print.
Scat makes A, B, & T cranks from the same forging. You can have your cranks custom made to any size you wish, so long as the forging is big enough...
ChrisB
First Name: Chris
Last Name: Brancaccio
Post by ChrisB » Thu Aug 01, 2019 11:04 am
The Synder's rod is not the same as the Scat rod. The Synder's rod has insert bearings and I understand the demand was not there so they are not making them anymore.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Last Name: Hatch
Post by Dan Hatch » Thu Aug 01, 2019 1:07 pm
Synder sells a NEW babbitted rod that looks just like a Ford T rod only it has an oil dipper made on it. I was wondering if the Synder rod was the Scat rod or what does the Scat rod number I listed look like? Dan
modernbeat
First Name: Jason
Last Name: McDaniel
Post by modernbeat » Thu Aug 01, 2019 6:43 pm
Dan, the photo in the Scat catalog of the 7.5" "A" rods looks the same as the "T" rods.
Jason McDaniel
Last Name: Hatch
Post by Dan Hatch » Thu Aug 01, 2019 6:53 pm
Part number of rod I am asking about is 2T7000-1250 short scat part number is 2T7000.
Not the A rod. Thanks Dan
modernbeat
First Name: Jason
Last Name: McDaniel
Post by modernbeat » Fri Aug 02, 2019 9:29 am
I'll order one and send it to you.
Let me know if you think you can do something with it.
Jason McDaniel
modeltbarn
First Name: Gary
Last Name: London
Post by modeltbarn » Fri Aug 02, 2019 7:32 pm
Dan
I have a set of these at home that I am not using. I'll be home tomorrow evening. If you send me your email pr phone I can contact you tomorrow. I listed these for sale awhile ago for well under the list cost because I don't have an engine to use them in.
Gary London
Last Name: Hatch
Post by Dan Hatch » Sun Aug 04, 2019 7:46 am
Thanks to Gary I now have an answer. Scat rods are not what I am looking for. Dan
John Warren
Last Name: Warren
Post by John Warren » Sun Aug 04, 2019 8:21 am
That’s too bad about the Snyder’s rods. I thought they were great built with dippers. 😢.
