Radius on big end bearings
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Post by John E. Guitar » Mon Aug 05, 2019 6:27 am
I’m machining new big end bearings for my 26 Tourer. What radius should I put on these? I found a mention of 1/16” as the fillet radius on the conrod journals on the crankshaft in a post on the old forum so I was thinking I should make it slightly bigger than that.
The pic below is a rod I used to test my setup.
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Re: Radius on big end bearings
Post by BobShirleyAtlantaTx » Mon Aug 05, 2019 10:19 am
The shaft should have a radius of 1/16 at the rod pins so I cut just a tad over a 1/16. Very nice looking pour, please show us your set up. Also the fixture for boring the rods. Bob 903 824 1949
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Aug 05, 2019 3:50 pm
Test rod?!?!? Looks more like a lightened racing rod to me!! ;)
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Mon Aug 05, 2019 8:27 pm
A 1/16” radius certainly will not work with a correctly ground crank!
John E. Guitar
Last Name: Guitar
Post by John E. Guitar » Mon Aug 05, 2019 10:37 pm
Bob, thanks, I'll go with that.
You've got a nice setup. It's interesting seeing how you've held the big end. That was the part I wasn't sure which way to go.
Here is what I came up with. The base and end plate is scrap 6061 T6, and the pin is mild steel. I've got our another bearing to pour this week, I'll take photos of my mold setup then.
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Tue Aug 06, 2019 12:22 am
The rod pictured has no babbitt it was used for setup. The fixture clamps the rod using pins and the large bolts on either side of aviation socket head bolts, cut flat on the inside of the head to go into the rod. The long, splicing nuts are used with a gauge block to check the straight and twist of the rod.
The bolts in the fixture push on pins that clamp against the socket bolts. The pins have a flat on one side and the small socket bolts keep the pins oriented.
Bill Crosby
First Name: Bill
Last Name: Crosby
* REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Post by Bill Crosby » Tue Aug 06, 2019 7:29 pm
This Is the rod boring setup that I have developed over the years.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
* REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Post by Kohnke Rebabbitting » Tue Aug 06, 2019 9:25 pm
C to C, is 7 inches.
Width is 1.500.
The Radius is exactly 1/8th.
First rod, Gold, is our Centrifugally poured Rods
Herm.
Jig Poured Model T Rods, Jan, 2012 026.jpg (21.86 KiB) Viewed 7087 times
John E. Guitar
Last Name: Guitar
Post by John E. Guitar » Wed Aug 07, 2019 10:04 pm
Bill, that is a great looking setup. The way you've done the big end adjustments must cut down on setup time a lot.
John E. Guitar
Last Name: Guitar
Post by John E. Guitar » Wed Aug 07, 2019 10:07 pm
Herm, thank you, that is good information.
Is the gold rod photo in your post as poured? Do you have a side-on photo? It's hard to compare it with the static-pour rod being from two different angles.
I can see you had leakage with the static-pour rod. I used a combination of aluminium welding wire and Eastwood heat compound to eliminate that. Do you think the colour variation would correspond with different grain structure? I noticed when I was machining one of my rods there seemed to be a few hard spots in the babbitt.
I'm envious of your centrifugal casting setup, the end result looks great.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Thu Aug 08, 2019 3:57 pm
On the leakage John, That was the first time we static poured, about 7 years ago, on Model T rods, and as the pour came out, we don't put up with leakage. So, I set up a jig to machine the rod sides. So the uneven machined sides, from previous rebuilding machine work, was gone.
I will show you the jig pictures, and machined rods, before pouring, it is a factory, Clawson & Bals.
The Gold rod is the one we always took to swap meets.
The dark rod is a clawson & Bals, spun poured Rod
Herm.
Model T Spun Poured Rod 018.jpg (27.26 KiB) Viewed 6939 times
Model T Spun Poured Rod 014.jpg (19.81 KiB) Viewed 6939 times
Model T Spun Poured Rod 012.jpg (21.79 KiB) Viewed 6939 times
Model T Spun Poured Rod 008.jpg (19 KiB) Viewed 6939 times
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Thu Aug 08, 2019 4:11 pm
More Pictures.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Thu Aug 08, 2019 4:21 pm
Pictures.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Thu Aug 08, 2019 4:28 pm
Pictures.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Thu Aug 08, 2019 4:42 pm
Pictures.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Thu Aug 08, 2019 4:56 pm
Pictures
The car is a 1908 Aplex, 2 Cycle, quite a Machine.
