How many cups of grease does it take...
Post by Steve Jelf » Sat Aug 10, 2019 6:40 pm
...to fill the space around the U-joint? Curious, I didn't put in any grease when I assembled the thing, just to see how many cups it would take.
The answer is 23, at least in this case. After the car has run a few miles the grease may be spread around to make more space.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Re: How many cups of grease does it take...
Post by SurfCityGene » Sat Aug 10, 2019 7:01 pm
The best idea I've seen for these type grease cups is to install a modern Zerk fitting inside the cup. It sure does make greasing the T a simple task. It's important to grease that U joint often..
1912 Torpedo Roadster
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Sun Aug 11, 2019 7:31 am
Loading 23 cups of grease must have felt like groundhog day!
Paranyos
First Name: Paul
Last Name: Aranyos
Post by Paranyos » Sun Aug 11, 2019 8:38 am
I love that experiment. I went through the same process 2 weeks ago, the following week I added a zerk.
A man has got to know his limitations!
Post by Steve Jelf » Sun Aug 11, 2019 9:50 am
Days. Arthur Itis suggested that it would be done best only five at a time.
Post by Original Smith » Sun Aug 11, 2019 9:58 am
I'm happy you shared that. It's much easier to pack the cavity before you slide the u-joint into the engine. Then, all you need is to fill the grease cup a few times. If you install a zerk, then how are you going to keep the grease cup from coming off? It's better to not use a zerk.
Post by TRDxB2 » Sun Aug 11, 2019 1:01 pm
You can buy them already made too, in steel or brass, for U-joint, steering, rear axle....
Post by Mark Gregush » Sun Aug 11, 2019 2:46 pm
"If you install a zerk, then how are you going to keep the grease cup from coming off? It's better to not use a zerk." Most of my grease cups for that size are not spring loaded if you are talking about the cap. If the cap unscrews from the base, you have more problems to deal with then just a lost cap. And even if you lost the cap it would be no big deal, no different then just installing a Zerk without the cup, both are pipe thread. I install mine dry and fill after, enough to deal with without the mess of grease everywhere. I find about 1/2+ tube of grease fills it from dry, but I am not going to go out a measure how many caps full that is! :lol:
Simple matter to unscrew the cup install a Zerk fill the housing then reinstall the cup for refilling later if you so wish.
Post by Original Smith » Sun Aug 11, 2019 8:03 pm
As the regulars on this forum know, I use original parts. The cap has a three or four sided stud which is welded to the cap. There is a spring affair that fits into the base, and when the two are engaged, it prevents the cap from loosening. Of course, if you have a zerk down there, it can't work.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Mon Aug 12, 2019 11:37 pm
I used one with a zerk when I assembled my drivetrain for the first time. It took 3/4 of a tube a grease to fill it from empty.
1924 Touring
Bud Delong
First Name: Kenneth
Last Name: DeLong
Post by Bud Delong » Tue Aug 13, 2019 8:37 am
Grease is cheap,but that much seem's if only to me excessive? Bud.
Post by DanTreace » Tue Aug 13, 2019 9:53 am
Bud
Can’t have too much grease in the u-joint ball, Ford used the largest dope cup there. Takes about a full cup of grease to pack.
Have always packed it full on install of the engine, filling the joint and space in the torque tube ball, allows for the square end of the u-joint to stand up and not wobble in slack as you couple. Keep that u-joint packed each 500 miles. :)
Post by Original Smith » Tue Aug 13, 2019 11:07 am
A cup of grease is a lot of grease, but 23? Give me a break!
Post by Steve Jelf » Tue Aug 13, 2019 11:41 am
No, no, no. Not eight ounce measuring cups. We're not baking a cake here. This is about Model T GREASE cups.
And yes, I really did fill it and screw it on 23 times before it filled the cavity enough for grease to start oozing out around the cap. (See the first picture I posted above.) I assure you I'm not running for office, so I'm not lying. :D
Last Name: Wrenn
Post by TWrenn » Tue Aug 13, 2019 4:21 pm
Like Dan said...if you have the engine out or rear end out just make sure and the ball full. And yep it does make it very easy to keep the universal in place for an easy coupling. Just did that last week. Very quick and easy hookup. Then every 500 miles I give the Zerk fitting cup 20-25 pumps and its good to go. Plus 4-6 on the driveshaft bushing. Never had any trouble with the caps staying on the cups either!
Ball joint packed full before connecting
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Tue Aug 13, 2019 9:49 pm
Filling the ball full of grease and continually adding more grease is like taking a whole bottle of aspirin. More is not better...
Post by RajoRacer » Tue Aug 13, 2019 10:25 pm
Quite a fitting analogy there, Adam !
JP_noonan
Last Name: Noonan
* REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
Post by JP_noonan » Tue Aug 13, 2019 10:35 pm
How is having the ball full then adding some after it squeezes out under normal operation a bad thing? I would think having it mostly full would be an advantage for a healthy u-joint, and for preventing engine oil from going down the torque tube and into the diff. Me confused. :?
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Aug 14, 2019 5:44 pm
Some grease squeezes forward into the transmission and engine. Modern grease does not mix readily with engine oil. Because the oil system is not pressurized, the grease has the ability to foul oil grooves and oil holes in the engine and transmission preventing proper lubrication. Grease also EASILY will plug up oil lines, even the accessory ones. It’s really important to keep any traces of grease out of non-pressurized engines.
Post by Original Smith » Wed Aug 14, 2019 9:34 pm
Too bad that Steve didn't mention grease cups in the first place!
Post by Steve Jelf » Wed Aug 14, 2019 9:55 pm
Huh?
:D
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Wed Aug 14, 2019 10:37 pm
If it's any small consideration, I got it right away Steve. I imagine some of us have been dealing with grease cups for all sorts of ancient machines for quite awhile. Me since I was a boy and never lost one yet but I am only 55. :lol:
Shoot, 5 cups at a time is a stretch!
I've lipped off about this before but I just took the entire, clean and correct cup assembly off the empty U-joint cover on the 18 and held the grease gun against the hole for the cup and started pumping. You prob'ly remember this, it took me a few tries to get it done but it was full. And a few more (grease) cups worth. Ouch. Then I sat down again and refreshed my self with a cold drink. :)
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Thu Aug 15, 2019 7:40 am
OK. I will ask the question. Adam replied that some grease squeezes forward into the transmission and engine and may plug oil lines and grooves. I packed my u-joint with the fiberous yellow truck wheel bearing grease in hopes that it would stay put and not run out like regular grease. I also considered using the red grease for heavy equipment that stays put. Do these types of greases pose more of a danger of plugging the oil lines? Am I asking for trouble? What is the best type of grease to use in this location?
Fire at will, gentlemen, Bill
Bud Delong
First Name: Kenneth
Last Name: DeLong
Post by Bud Delong » Thu Aug 15, 2019 8:45 am
I think most old time grease/dope cups often used what was called [soft oil].I have doubts about filling the engine with grease and if said grease is not soft or a semi fluid,how will it get into the inner parts of the U joint? Grease and oil are cheap but is there a need to under coat your car and leave a trail??Bud.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Thu Aug 15, 2019 8:52 am
What kind of grease is recommanded?
Super Mario Bross ;)
1911 Touring
1914 Speedster
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Thu Aug 15, 2019 10:58 am
Yo tambien.
It never even crossed my mind that this might be referencing baking (Imperial) measurements.
1924 Touring
Mopar_man
Last Name: Govoni
Post by Mopar_man » Thu Aug 15, 2019 9:48 pm
Great info here. I always like reading what you write Mr. Jelf. I learn something every time. This was a good experiment. I bet there are many who just think that a few turns is ok on the cup.
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Fri Aug 16, 2019 1:42 am
Sorry Steve, drifting. Off the deep end but goll (Gol Ducat) I laughed! Intended or no, you guys made my good day great! Again!
Don, doggone it, you were speaking the Queen's Spanish and all I heard was French! I saw "Combien du temps" (combien du tom) in my head "How much time?" Hah! still relevant! :)
I had to look "Yo tambien" up! :lol: Me too.
You have a twisted sense of humor that suits and yet out performs my own! IMPERIAL MEASUREMENTS... :lol: Still laughing inside!
All I hear in my head NOW is my brain feeding me an English accent voice-over of the whole darned thing...
Nyes, we see that the hole bloody mess has to do with how many copps we ectually put into that bloody swivel-joint mmm?...... :lol:
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Fri Aug 16, 2019 7:56 am
Duane.... :D
I was raised in a farming community just north of Brownsville, TX and Spanish was practically my first language.
1924 Touring
Post by Steve Jelf » Fri Aug 16, 2019 9:08 am
...Spanish was practically my first language.
Here we go again, with a comment reminding me of something else. My late compañero de trabjo Carlos Sotelo was from Ojinaga, Chihuahua. I once asked him, "Why Kansas?" He said that for the first two years after he came to the US he lived in Texas, and realized he wasn't learning English. So he moved to where he would have to. :)
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Sat Aug 17, 2019 1:06 am
:lol: I got it pretty close Steve. A traveling buddy I thought. :)
Up here we know a little Norwegian, a bishen German and I obviously gravitate to French. Mostly swear words. :lol:
Interesting! :)
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Sat Aug 17, 2019 5:11 pm
I've been having a lot of work done on my property lately and in this area, most of the laborers who are employed by contractors are hispanic.
With the severe heat the way it is around here in August, I've taken cold drinks out to the workmen and almost always take some time to chat with them (in Spanish) while they cool down. My kids are awestruck by my ability to not only converse with these guys, but to do so seemingly without an accent.
I think their amazement is due, in part, to the fact that I never speak Spanish at any other time.
I was thinking about it the other day. My dad farmed and raised cattle and so did his father. They dabbled in other things, but they were farmers above all else. As far back as we've been able to research, all the Allen men have farmed and raised cattle. This probably stretches back thousands of years. I broke the chain and now live near a city and wear a lab coat at work. My dad sold everything farm related and moved away from south Texas before my kids were born so they've never experienced something that their ancestors did since practically the beginning of time.
Talk about something that will stop and make you think for a minute.
Sorry about the thread drift Steve. I'll go squirt some more grease into that u-joint zerk this afternoon to get things back on track.
1924 Touring
ArthurB
First Name: Arthur
Last Name: Babitz
* REQUIRED* Type and Year of Model Ts owned: 1927ish Roadster Pickup
Post by ArthurB » Sat Aug 17, 2019 8:25 pm
I can verify Adam's comment about some of the grease working its way into the transmission. I pumped away at my zerk fitting, never seeing any grease come out of the U-joint cover. Next time I opened the transmission cover plate I found what I first thought was a dead mouse in the screen. It was a big glob of grease partially dissolved by the engine oil into a very mouse-like shape. It even had a tail. Should have taken a picture, but my hands weren't very clean.
It never occurred to me to check the oil lines, but I will do that now.
