Spring Source
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Spring Source
Post by Will_Vanderburg » Wed Aug 14, 2019 2:36 pm
Need a source for the spring inside the door of a Center Door sedan.
I cannot seem to match the correct length to wire thickness and spring diameter.
William L Vanderburg
1922 Center Door Sedan
Will_Vanderburg
First Name: William
Re: Spring Source
Post by Will_Vanderburg » Wed Aug 14, 2019 2:41 pm
Mine are approximately 8 inches in length total with elongated hooks, 0.11 inch wire diameter and 0.69 spring diameter
Re: Spring Source
Post by Scott_Conger » Wed Aug 14, 2019 4:01 pm
