Can anyone identify this nos aftermarket radiator close to a Model T but taller
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Sat Aug 17, 2019 9:28 am
I just got this radiator in it is nos from a very old aftermarket
customer who had this says he had owned it since the 50's and he got it from a farmer
pictures not the best because its sitting on a white pad very clean
the neck and shape of the tank are different as well is the inlet and outlet
very similar to a T
measures about an inch taller than a high radiator and about one and a half inches narrower
23 3/8 tall from top of tank to bottom of tank
18 7/8 wide
notice the stamped mounting plates and where the overflow tube is mounted
any help appreciated, Bob
FATMAN
First Name: ROBERT
Re: Can anyone identify this nos aftermarket radiator close to a Model T but taller
Post by FATMAN » Sat Aug 17, 2019 9:29 am
few more pics
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Sat Aug 17, 2019 9:39 am
Totally WAG, coming from a farmer, I bet it's for a tractor...
Post by Mark Gregush » Sat Aug 17, 2019 11:11 am
The stock radiator on my 25 is just under 24" top to bottom. So 23-3/8 would be just a little short but not enough to worry about.
FATMAN
First Name: ROBERT
Post by FATMAN » Sat Aug 17, 2019 12:50 pm
could it be Metz?
Bob
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Post by BHarper » Sat Aug 17, 2019 1:55 pm
Hi Bob,
No, it is not a Metz radiator, well, it is not for the Model 22 or the Model 25. I can't speak to the later 6 cylinder cars, but I doubt that it would fit.
Could it be intended to be used with one of the period aftermarket speedster kits with a higher radiator shell?
Bill Harper
Keene, New Hampshire
Post by Mark Gregush » Sat Aug 17, 2019 2:15 pm
Please read my post. It is just a about the same or just little shorter then a stock T high radiator. Not including the neck, from the bottom to top.
FATMAN
First Name: ROBERT
Post by FATMAN » Sat Aug 17, 2019 2:45 pm
when I pit a high shell on it its about a inch from the mounting plate if I remember right I will try when I get back to the shop, Bob
kmatt
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
Post by kmatt » Sat Aug 17, 2019 5:16 pm
Bob, What is the measurement between the mounting points to the car frame ? Per your measurements the core is 18 7/8" wide, a stock Model T uses 21 1/2" wide between mounting points. It looks like it could be close to stock T width, if so, maybe it fits a custom speedster body of unknown to me make.
Post by John kuehn » Sat Aug 17, 2019 5:51 pm
The radiator looks like a tractor radiator from the 40’s and 50’s. Not for sure but tractors in that era had radiators similar to a T. But also it could be for a car in that era. Try a high T radiator shell and see how it fits. Then you would know for sure. Maybe the rubber pads are used for spacers to raise it up besides used for cushioning.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sat Aug 17, 2019 6:37 pm
No guesses but not many tractors had the hood rod down the center.
kmatt
First Name: Kevin
Post by kmatt » Sat Aug 17, 2019 7:08 pm
Pictures from the 2016 forum of what is thought to be a Morton Brett radiator. Notice that the radiator core construction is similar to this radiator.
http://www.mtfca.com/discus/messages/59 ... 1470717303
FATMAN
First Name: ROBERT
Post by FATMAN » Sun Aug 18, 2019 10:31 am
Measurements, Bob
