I ran my speedster with a 23 radiator for many miles without any heating problems. I recently changed the front end and radiator to a
14 brass, which was suppose to be new. After about 6 miles it started to get hot and boil. I have not changed any timing or anything else that would be related to heat problems. Any suggestions as to the problem would be welcome.
Over heating
Topic author - Posts: 37
- First Name: Sam
- Last Name: Mendenhall
- * REQUIRED* Type and Year of Model Ts owned: 14 Speedster
- Board Member Since: 2014
Re: Over heating
Did YOU purchase the radiator new or was it purchased as a "new" one by you ? Flat tube or round ? Perhaps it was sold because it didn't cool ?
- First Name: Henry
- Last Name: Lee
Re: Over heating
Good catch Steve!
I ran into this once, drove me nuts. The baffle was place to low and starved the condensing process!
Just saying.
Just saying.
- First Name: Jim
- Last Name: Davis
Antifreeze
Did You use antifreeze in the old radiator. I read that antifreeze will raise the boiling point well above 212 degrees and if Your not using it in the new one could make a difference But one would think the new brass radiator would be able to dissipate as much heat as a stock T engine produces. If Your engine is souped up it could perhaps produce more heat. also any fan or radiator spacing changes could affect it. could also be a flow restriction of some sort that doesn't show up until You have been running hard for a while.
Good Luck
Jim
My 2 cents worth maybe less
Good Luck
Jim
- First Name: Bryan
- Last Name: Ostergren
- * REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
Re: Over heating
A friend of mine bought a new radiator for his '26, installed it and it overheated almost immediately. Turned out there was a plug in the water outlet that he failed to notice. It had quite the detrimental effect on coolant circulation!
- Last Name: Hanlon
Re: Over heating
Sure sounds like the "new" radiator is the root cause. As long as you don't have a leaking head gasket...
