If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
Bill Robinson
- First Name: Bill
- Last Name: Robinson
Post
by Bill Robinson » Mon Aug 26, 2019 12:42 pm
While on the MTFCA Highland Rim Tour, I personally saw 4 T's that blew head gaskets. I was told that there were actually 7 T's that lost one. One car blew 2 because he failed to re-torque the head after a warm-up.
So, the next time you walk out to your shop, grab your torque wrench and RE-Torque the head on your engine(s). Don't gamble and don't assume.
3 minutes and you'll be done.
- First Name: Henry
- Last Name: Lee
Post
by Henry K. Lee » Mon Aug 26, 2019 1:05 pm
Bill Great Reminder.
I retorque my heads multiple times!
Have never blown one.
Post
by RajoRacer » Mon Aug 26, 2019 1:28 pm
I'm in Hank's "camp" - a minimum of 3 heat/cooling cycles and I've probably installed over 100 + Model T & A heads & yet to have a failure !
thom
- First Name: Tommy
- Last Name: Coffey
- * REQUIRED* Type and Year of Model Ts owned: '21 Touring
Post
by thom » Mon Aug 26, 2019 1:44 pm
I would never change a head gasket and not retorque it. Matter of fact, I think I'll go out and check mine again now. I'll clean my plugs and wipe out the New Day timer while I'm at it. Thanks for the reminder.
Post
by Norman Kling » Mon Aug 26, 2019 1:53 pm
The first time I changed a head gasket, 67 years ago, I didn't re-torque it, in fact I just tightened down the bolts in any order. As soon as the engine warmed up, I blew the gasket a few blocks from home. Learned that lesson and have not had one blow since.
Dan B
- Last Name: Blaydon
Post
by Dan B » Mon Aug 26, 2019 2:11 pm
How does one know when they blow a head gasket? And is any permanent damage caused?
Bill Robinson
- First Name: Bill
Post
by Bill Robinson » Mon Aug 26, 2019 2:21 pm
One of the cases that I saw was in the parking lot at the fairgrounds. A Model T was coming off the city street "just 'a 'smokin". When the driver came by me his exhaust smelled like anti-freeze. This is just one of the signs.
Ruxstel24
- Last Name: Hanlon
Post
by Ruxstel24 » Mon Aug 26, 2019 4:20 pm
Dan B wrote: ↑Mon Aug 26, 2019 2:11 pm
Usually it'll overheat or run poorly.
Unless you get a bunch of coolant in the oil for an extended period of time...no real damage.
walber
- First Name: Walt
- Last Name: Berdan
- * REQUIRED* Type and Year of Model Ts owned: '18 Speedster had 25 touring and 26 coupe
Post
by walber » Mon Aug 26, 2019 4:43 pm
Any blown gasket is a message to you to check the mating surfaces to ensure they are flat. In the case of head bolts, also time to verify the bolts don't bottom out in the block before getting fully tight. I check bolt/hole individually by laying the head on the block with no gasket and making sure they tighten up to the head rather than standing a bit proud. If the surfaces are flat, the bolts don't bottom out and are properly torqued (and retorqued) there shouldn't be any blown gaskets.
Post
by TRDxB2 » Mon Aug 26, 2019 5:29 pm
Would have been nice to know what type of gaskets blew... too much to ask how they were prepped.
- Last Name: van Ekeren
Post
by Kerry » Mon Aug 26, 2019 5:52 pm
A lot of variables on why a head gasket can blow, 7 are a lot in one tour! our nationals can have up to 140 T's for a weeks worth of driving and no head gasket problems.
Re-torque on the type of head, cast or aluminium, how it was done, surface condition etc, are usualy the things that contribute to a failure before you can blame the gasket it's self.
Doug Keppler
- First Name: Douglas
- Last Name: Keppler
Post
by Doug Keppler » Mon Aug 26, 2019 8:16 pm
My engine is newly rebuilt and has maybe 25 miles on it, when I assembled it I carefully hand tightened All the bolts. While recently installing an air filter
with a bracket that bolts to one of the crankcase bolts I noticed the bolt wasnt very tight so I went around and checked every bolt on the engine and almost every one snugged up a little. So I think not only the head bolts need to be retorqued, check all the bolts, it might slow down some oil leaks also.
1924 Touring car
There's No Substitute for Proper Lubrication
Post
by RajoRacer » Mon Aug 26, 2019 9:52 pm
Blue Loktite should be every Model T owners friend & in the tool kit !
