I am restoring a 1912 brass windshield hinge for a member and would like to know If anyone can tell me the type of brass that It's made from ?
Thank you
Bill
1912 Model T Brass Question
Bill Crosby
Topic author - Posts: 184
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
- First Name: Henry
- Last Name: Lee
Re: 1912 Model T Brass Question
Hi Bill,
I believe they are the same as cartridge brass.
Hope this Helps!
Hope this Helps!
Bill Crosby
- First Name: Bill
- Last Name: Crosby
Hank, I will look It up and see If that helps define It.
Thank you
Bill
Thank you
Bill
Although Ford was quite specific about many of the parts and materials used in manufacturing his cars, I suspect something like a windshield hinge varied quite a bit from manufacturer to manufacturer, and even batch run to batch run. Windshields that early were supplied by a few companies.
It would be interesting to know the story behind the necessary repair to the hinge. I have twice repaired reproduction hinges on my 1912 Haigh's chocolate van. The problem is in the manufacture flat of these. The reliefs in which the studs/nuts sit is machined flat, but that machined land is done with a plunge cutter and there is a perfectly sharp edge to the machining. This creates a wonderful stress riser, from which two of my hinges have cracked. All that is required to fix this is for the makers to use a cutter with a radius so there is no stress riser. I won't hold my breath!!
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Original Rands brass hinges can also crack. It can be hard to find a set in good condition.
