Nails for ignitions coils
keen25
First Name: Eric
Last Name: Keenan
* REQUIRED* Type and Year of Model Ts owned: 1923 coupe, 1925 TT, 1926 coupe, 1925 Tudor, 1925 pickup, 1926 fordor
Post by keen25 » Fri Aug 30, 2019 11:54 am
Is there a supplier for the 2 small nails used in the Ignition coil to hold the cover on?
thank you, Erick
Re: Nails for ignitions coils
Post by Mark Gregush » Fri Aug 30, 2019 12:13 pm
You should be able to find the wire brads at a good hardware store. Personally, I staple the door in place. Makes it easier to get into later if needed.
Post by Original Smith » Fri Aug 30, 2019 4:29 pm
The 1914 and earlier KW coils use brads. I don't know about the other brands. Check with RV, he knows for sure.
