On...or...Off ???
George Mills
Last Name: Mills
On...or...Off ???
Post by George Mills » Tue Sep 03, 2019 4:55 pm
I’m a guy who only has use of one leg....so working on de-gunking dirty fuel system has driven me nuts and taken months since I can only get down and under 2 times and can’t use a creeper and then spend 2 days recovering...lol
To save my mind and a trip under....is this Open or Closed ? I’m having a brain-spasm today 🤔
Re: On...or...Off ???
Post by Scott_Conger » Tue Sep 03, 2019 5:03 pm
George
it's "on"
George Mills
Last Name: Mills
Post by George Mills » Tue Sep 03, 2019 5:11 pm
Thanks Scott,
This things driving me nuts...but I’ll prevail...eventually.
Move back! Lol
Moxie26
Last Name: Jablonski
Post by Moxie26 » Tue Sep 03, 2019 10:56 pm
George:
Are you riding out the storm in Florida, or elsewhere ??????? PM me as you wish.
Bob J.
bobt
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1915 touring 1926 roadster
Post by bobt » Wed Sep 04, 2019 5:19 am
I put a SMALL pinpoint of green paint on the handle and another on the fuel line so when they line up, It's "on" Works for me. Bobt
George Mills
Last Name: Mills
Post by George Mills » Wed Sep 04, 2019 8:28 am
Bob T great idea! I’ll take that...
Bob J we are over on the Gulf coast so spared this time once the errant spaghetti models decided to join the rest from Sunday on...
Post by Original Smith » Wed Sep 04, 2019 10:48 am
If the handle lines up with the gas line, it's on.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Wed Sep 04, 2019 10:59 am
Its on and when the pinion line up the gas line or if the pinion pointed the carb is off. Hope that help! I have the same pinion wich is original.
Super Mario Bross ;)
1911 Touring
1914 Speedster
Post by Norman Kling » Wed Sep 04, 2019 11:06 am
Those who posted are very likely correct, but a positive proof, if the engine will run would be to turn the valve in the direction toward the carburetor and run until it runs out of gas. If that doesn't happen within a few minutes, try the valve in the other direction and you will know for sure. Problem with having the valve at that location, it will work for parking to keep from draining the tank, but you will still need to crawl under to turn it off if you want to remove the carburetor.
NHUSA
First Name: Fred
Last Name: Dimock
* REQUIRED* Type and Year of Model Ts owned: 1919 T with Mifflinburg Suburban body
Post by NHUSA » Wed Sep 04, 2019 12:32 pm
That used to confuse me also. :?:
Finally I drew a picture on the garage wall so I didn't forget. :idea:
It helped me when I was at home but I couldn't take the garage with me on a trip. :lol:
NH - Where I used to live - not the carburetor ! :lol:
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Thu Sep 05, 2019 10:57 pm
I'm so darned forgetful and so many valves to remember. 80's Kubota engine coolant drains and even 100 year old water drains on some engines/tractors are opposite of what one might expect but coolant drains are easier to learn. With a piece of wire to test!
My solution.
UGH, yes I know it's a rats nest of incorrect in there. :lol:
WayneJ
Last Name: Jorgensen
Post by WayneJ » Fri Sep 06, 2019 9:09 am
It is somewhat comforting to know I am not alone. I took a picture of my valve in the open position and store it on my phone in a separate "album" titled: "starting model t", so I can remember.
Wayne Jorgensen, Batavia, IL
1918 Runabout
