early ? rear frame crossmember question
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Thu Sep 19, 2019 10:20 pm
Gentlemen:
I have a frame portion with a short rear crossmember … it may have been cut off or may be original … there is some signs of breakage or "tampering"... not sure what the early frame really looked like to be certain ...there is no front crossmember or frame brackets or running board brackets
… any help in a positive id. would be appreciated ...always an optimist gene french
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Re: early ? rear frame crossmember question
Post by Ken Buhler » Thu Sep 19, 2019 10:57 pm
It was cut off. Easy to replace but first check the rails for correctness and straighten before replacement.
Work honestly
Stay true to your word
Get the job done right
Post by DanTreace » Fri Sep 20, 2019 9:08 am
Gene
Just for ref., here's an early frame that didn't have the rear overhang of the crossmember, as the early fender brackets acted as body brackets too, and were mounted direct to the frame.
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Sep 20, 2019 10:01 am
Dan:
thanks for the photos … I was uncertain that this was a correct frame since some of the details were poorly finished … always an optimist ...gene french
