Are the rear spring the same between Ts?
Will a small drum mount up to a set of springs that came off of '26/'27?
I am thinking that there is not any difference, but I have been wrong before.
rear springs same
Mustang1964s
Topic author - Posts: 272
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Bill Robinson
- First Name: Bill
- Last Name: Robinson
Re: rear springs same
Go to this mans website and you will see that there are a few different spring sets for a model T.
http://t-springs.com/products.html
There is a difference in the arch of the springs, 09-25 (small drum) vs 26-27 (large drum), and the spread length 46-3/8" vs 43-1/4" respectively. Also the rear cross member on the frame needs to match. Haven't tried it so can't answer the question - will it fit
Mustang1964s
The two rear ends that I have are '26/'27 and they are currently out of commission.
I am trying to gather part to rebuild.
A club member has let me borrow a small drum Ruckstell.
Besides not having a hand brake. What other issues am I looking at?
The 1928 parts book listed the rear spring as the same 1909 to 1927;
http://www.cimorelli.com/mtdl/post-1927/1928plaug.pdf
The arc of the rear cross member was changed for 1926-27, it was taller to drop the body down. I mounted a big drum rear under my 21 without changing the spring with no issues. The only difference might be the number of leafs between body styles.
