Dupont Acrylic Lacquer paint 99L
24tcoupe
First Name: Laird
Last Name: Powers
* REQUIRED* Type and Year of Model Ts owned: 1924 Model T Coupe
Post by 24tcoupe » Fri Oct 04, 2019 10:30 pm
I am looking for some of the old Dupont 99L Lacquer paint for my 1924 T. I painted it back in the early 80's and am now in need of some more paint for touch up. Any amount will do, opened or not opened.
lesvonnordheim
First Name: Les
Last Name: Von Nordheim
Re: Dupont Acrylic Lacquer paint 99L
Post by lesvonnordheim » Fri Oct 04, 2019 10:48 pm
I don't think Lacquer paint is still available in Calif. Even "Gun Wash" is no longer Lacquer. This is all because of EPA rules in Calif. They would like us to use water base paints which I have used but do not like. You may be able to order or buy Lacquer paint/thinner by mail or go out of state to get it.
Most paint offered by the paint stores in Calif. is "Base Coat/Clear Coat. Some still provide Urethanes and Polyester primer.
Good Luck,
Les
jiminbartow
Last Name: Patrick
Post by jiminbartow » Sat Oct 05, 2019 1:56 am
Do you have the old can? If so, can you post a picture of it?
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Sat Oct 05, 2019 8:41 am
Hibernia Restoration in NJ has what you need. They were able to match the lacquer I painted my car with in 1970 perfectly. They say they can ship to all 50 States.
