Steering case position Question
lorenzo26
Topic author - Posts: 50
- First Name: lorenzo
- Last Name: leon
- * REQUIRED* Type and Year of Model Ts owned: 2 doctors coupe
does the groove go up or down??
- Attachments
- 103927.jpg (32.86 KiB) Viewed 2661 times
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Steering case position Question
Up
Figure 395 shows the slot at the top, and that is where it is on three columns I checked. A practical reason for this when rebuilding a column is that is the way the rivet holes will line up, the assemblies seemingly individually fitted. Additionally, the long peg which engages in the slot has a direct relationship to the keyway for the pitman arm.
