If anyone has one or more of these that have broken or otherwise performed poorly and are no longer wanted, I'd be interested in buying them.
These are the long style tubing brackets that mount to the outside of the body at the front seat.
PM me at rvmodelt AT netsync DOT net
Broken early style horn tubing brackets
R.V.Anderson
Topic author - Posts: 680
- First Name: R.V.
- Last Name: Anderson
- Attachments
- 474510s.jpg (3.85 KiB) Viewed 2236 times
R.V.Anderson
- First Name: R.V.
Re: Broken early style horn tubing brackets
Gosh Randall, I can't believe you want to deal with that junk! Of course if you are going to modify it to look like what Ford actually used then you are forgiven!
