Tool is this for fastners on the tops or something else
FATMAN
Topic author - Posts: 1697
- First Name: ROBERT
- Last Name: BERGSTADT
At 1st I thought this was a riveting tool then a punch but the bottom piece is spring loaded and moves a friend says it might be for putting fastners on upholstery or tops any ideas? Bob
Re: Tool is this for fastners on the tops or something else
It is a riveting tool. Use mostly in the harness trade to set hollow end rivets but can be used to set band rivets and with modified anvils brake rivets.
FATMAN
Thank you, Bob
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Mainly for riveting leather as Mark Gregush says but can be used with some other applications.
Rex Riveters are very common - I see them on a regular basis at estate sales, antique shops and swap meets. You can still purchase brand new Rex Riveters.
Google Rex Riveter to learn more:
https://www.google.com/search?q=rex+riv ... e&ie=UTF-8
Photos:
https://www.google.com/search?q=rex+riv ... 80&bih=666
Photos:
How about brake band rivets?
Mark Osterman
- Last Name: Osterman
I’ve used one for installing band linings for years.
BobD
- First Name: Bob
- Last Name: Doris
What is typically done to repurpose these for band riveting?
