Lubricating A T
Lubricating A T
Post by Original Smith » Sat Oct 26, 2019 4:54 pm
Here is an area many people forget to oil. When needed, oil the clevis pins for the brake rods, and controller shaft, and what about the cam for the clutch? What about the Timer swivel joint on early cars? Something to think about.
Last Name: Strange
Re: Lubricating A T
Post by CudaMan » Sat Oct 26, 2019 6:12 pm
You're going to hate me for it, but I spray those areas with white lithium grease. It stays put instead of dripping onto the ground. I also spray the brake and reverse pedal cams with it. :)
Re: Lubricating A T
Post by Mark Gregush » Sat Oct 26, 2019 6:21 pm
While I do lube my clevis/pins I have seen suggestions not to because the lube holds the grit and grime and promotes wear. While motor weight oil should work I however use 600W or such on mine, same with other areas where metal touches metal such as carb and timer rods.
First Name: Henry
Last Name: Lee
Re: Lubricating A T
Post by Henry K. Lee » Sat Oct 26, 2019 6:22 pm
I am with you Mark but I use motorcycle chain lube.
First Name: Henry
Last Name: Lee
Re: Lubricating A T
Post by Henry K. Lee » Sat Oct 26, 2019 6:23 pm
Mark Strange that is.
Re: Lubricating A T
Post by Mark Gregush » Sat Oct 26, 2019 8:35 pm
Some people say that about me! :lol:
ewdysar
First Name: Eric
Last Name: D
Re: Lubricating A T
Post by ewdysar » Sat Oct 26, 2019 11:01 pm
The little trigger can oiler in my garage is filled with chainsaw bar oil. It seems to hang around longer than motor oil.
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Re: Lubricating A T
Post by Burger in Spokane » Sat Oct 26, 2019 11:07 pm
I use the same oil can and chain saw bar oil as the last poster. As for holding road grit, ....
one really ought to check these lube points with some regularity and not let the mung build
up.
Last Name: Seth
Re: Lubricating A T
Post by perry kete » Sun Oct 27, 2019 9:48 am
Larry,
Thank you for the reminder... I am past due on checking those oil points and will do so soon.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: Lubricating A T
Post by D Stroud » Mon Oct 28, 2019 4:13 am
As for the lube/don't lube argument about the lube attracting grit, I've heard that same argument from back in the '60's from farmers regarding farm equipment. Trust me, ANY lube is far and away better than none, rust and dry parts will eat up components far faster than oily grit. Been there, done that. ;) Dave
1925 mostly original coupe.
