A little parts quiz
A little parts quiz
Post by Steve Jelf » Sun Nov 03, 2019 11:26 pm
I just came across this quiz from about six years ago./
Lots of people can ID some or most of them. I wonder if anybody can name all ten.
Re: A little parts quiz
Post by Scott_Conger » Sun Nov 03, 2019 11:39 pm
leather saddle pad
carb throttle shaft staple
KW/Ford coil adjust nut
Holley pickup tube
carb inlet elbow
tire valve clamp ring (under #7 when not stamped into it as one piece). Usually Dill.
tire valve bridge washer
common sense fastener
perch/spring bushing
wheel spindle bolt/nut
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Mon Nov 04, 2019 12:11 am
2, 4 and 8 stump me. 10 looks like the bolt on a rear wheel hub holding the drum. If you redo that now you need a grinder because there is no difference between front and rear bolts.
Post by Allan » Mon Nov 04, 2019 12:17 am
Going on proportions, that is a front shackle bush. I don't see a valve stem use for the washer, unless it is used under a repop bridge washer with no inbuilt ridge.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Nov 04, 2019 1:22 am
1) leather saddle pad
2) carb throttle shaft staple
3) KW/Ford coil adjust nut
4) Holley pickup tube
5) carb inlet elbow
6) Valve retainer washer
7) tire valve bridge washer
8) carburetor float attachment and pusher for float valve (Holley G?)
9) perch/spring bushing
10) wheel spindle bolt/nut
Keith
Gene
First Name: Condon
Last Name: Story
* REQUIRED* Type and Year of Model Ts owned: 1911 torpedo 1916 tractor conversion 1922 roadster 1923 hack 1926 4 door 1926 1 ton truck
Post by Gene » Mon Nov 04, 2019 2:53 am
4 got me
MWalker
Last Name: Walker
Post by MWalker » Mon Nov 04, 2019 7:41 am
Gene -- It's from a Holley G carburetor.
Post by Steve Jelf » Mon Nov 04, 2019 9:12 am
Nobody got all of them yet, but one person got 90%. I'll post answers this evening.
Post by Scott_Conger » Mon Nov 04, 2019 9:29 am
Yeah, I dorked up #6 and don't know why...DOH! So obvious.
actually the separate bridge washer piece looks a lot like that but that's not what it was.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Mon Nov 04, 2019 9:43 am
#6 Looks like the seat base mount washer typical to tudor sedan passenger seat bases. I think that’s the one everyone missed.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Mon Nov 04, 2019 9:48 am
#8 is from a Kingston L2 carburetor. Holley G had an offset at the bottom and was put together a bit different.
Post by Scott_Conger » Mon Nov 04, 2019 10:05 am
Adam
I think you're right
and I just blew up the picture for the first time and see that I goofed up on #8 as well. Was up too late last night!
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Mon Nov 04, 2019 11:35 am
You guys need a hobby.
oh wait..... ;)
1924 Touring
Post by Mark Gregush » Mon Nov 04, 2019 12:06 pm
3, 6 and 8 were stumping me (didn't blow up the picture to see 8 better). I discounted 6 as being a valve spring seat as the hole is too big. 3 could also be a coil box terminal nut.
Post by Steve Jelf » Mon Nov 04, 2019 10:43 pm
OK, here we go.
1 Top saddle leather
2 Choke/throttle staple
3 Coil box terminal nut
4 Holley G idling pickup tube
5 #6154 carb inlet elbow
6 valve spring retainer
7 valve stem bridge washer
8 carb float hinge
9 front spring/perch bushing
10 hub bot & nut
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Tue Nov 05, 2019 9:24 am
Hey Steve, Are you mistaken on #6? The hole looks WAY too big...
Post by Steve Jelf » Tue Nov 05, 2019 3:00 pm
I could be. I can't find any record of the answers when I posted this quiz almost seven years ago. Here's the original picture of #6. Blowing it up to full size loses a lot of resolution.
Here's a for sure known valve spring retainer. I agree with Adam. The hole in #6 looks too big to match. So now I've mystified myself. I didn't find any radiator washers that match either, so I'm stumped.
Post by Scott_Conger » Tue Nov 05, 2019 5:16 pm
I'm still suspicious that it is one of the various mfg loose clamp rings placed under the bridge washer
Yes, it has a round hole, but frankly I do not see how that materially would affect it's operation when installed
Post by Mark Gregush » Wed Nov 06, 2019 11:49 pm
The bridge washer would be flipped over when installed and press down on the washer when the stem nut was tightened when the stem is just inserted in the tube. The raised area on the washer would press down on the tube to seal it around the stem. The washer would/could be used under the bridge washer type shown that does not have the raised area embossed in it. The just bridge washer shown would work for tubes that have the stem vulcanized to them without the additional washer under it. Ok that is how I see it.
kmatt
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
Post by kmatt » Thu Nov 07, 2019 12:08 am
Steve: Many years ago I remember having a 1920's, pre 1926, aluminum hub fan with stock arm and fan blades, the one with the oiling plug. On the back side of the hub it had a cupped washer with felt and a smaller flat washer between the felt and the fan hub bushing. That cupped washer looked like the #6 unknown part.
Post by Allan » Thu Nov 07, 2019 8:23 pm
Kevin, that is a good thought, but I don't think it is correct either. That washer is quite thin. The base is flat, and the sides are at right angles rather than rounded as this one shows. The transition from the flat to the right angled sides is quite narrow and sharper than this one. I can't find one to photograph it at the moment.
Daniel828
First Name: Daniel
Last Name: Brennan
Post by Daniel828 » Sat Nov 09, 2019 5:57 pm
I think I found what the washer is from
Does this resemble the one Steve posted?. I can’t tell the size from his pics
jab35
Last Name: Bartsch
Post by jab35 » Sat Nov 09, 2019 7:28 pm
Generator oil slinger?
Post by Scott_Conger » Sat Nov 09, 2019 9:43 pm
that particular one looks like a felt retaining washer from a generator ball bearing
Daniel828
First Name: Daniel
Last Name: Brennan
Post by Daniel828 » Sat Nov 09, 2019 11:13 pm
Yup. That’s the felt retainer on the bearing on the brush plate end of the generator. Is that the washer in Steve’s pics?
Post by Mark Gregush » Sun Nov 10, 2019 2:55 am
While the part shown in the last two photos is the generator oil slinger, it is not the same as one shown in Steve's first photo.
Post by Scott_Conger » Sun Nov 10, 2019 11:17 am
Mark, you're right, it's not the same part as in Steve's picture, but you're at the wrong end of the generator...it's not the slinger, though, the slinger is cup-shaped, so sort of 1/2 right... :)
I am curious, though, if the bearing-felt retaining washer pictured would in fact have been listed as a slinger or a washer...since only a few drops of oil are involved at that end of the generator vs the front, I'd bet it is just "washer".
Post by Steve Jelf » Sun Nov 10, 2019 12:01 pm
The quiz photo was a low tech affair, with all the pieces laid out together in a single shot. We know the front spring/perch bushing is 2", so compared to that the mystery item appears to be a hair under 1½". That should rule out some suspects.
Daniel828
First Name: Daniel
Last Name: Brennan
Post by Daniel828 » Sun Nov 10, 2019 3:39 pm
Dang, I was putting a new armature into my generator and saw that felt seal washer and thought for sure I was onto something
Post by Allan » Sun Nov 10, 2019 7:59 pm
Steve, the rear spring perch bushing is 2". Front ones are 1.5". That makes a difference when making estimations. I still don't know what the washer is!
