thermostat part number
bobt
Topic author - Posts: 303
- First Name: Robert
- Last Name: Thompson
Anybody know the part number for a 160 degree thermostat that I can buy at a local parts store? 1915 T touring. Thanks, bobt
- First Name: Dallas
- Last Name: Landers
Re: thermostat part number
I do not know but am curious why you need a T stat fot your touring ?
Novice
- First Name: Jim
- Last Name: Davis
COOD BLOODED T
Langs has 160 & 180 degree Thermostat's and gaskets $8.25 & Gasket $1.95 P/N A-TH160 & A-TH180. My 26 touring with a water pump and no hot air pipe runs too cool and is slow to warm up could use a thermostat. The 26 truck without a WP and with a hot air pipe seems to warm up OK here in Texas but up North all bets are off. I would be concerned about flow restriction with a thermostat effecting the thermosiphon action. a piece of card board over part of the radiator in the winter might be a better way to go ? if You car is cold blooded.
