Question about new tool??
Last Name: Hatch
Post by Dan Hatch » Thu Nov 14, 2019 11:14 am
I am think about making a run of 13/32 x 16 taps. I will need to know if there is any interest in these taps? Post here or email me at address in pictures. Thanks Dan
Fire_chief
First Name: Charlie
Last Name: Gagel
Re: Question about new tool??
Post by Fire_chief » Thu Nov 14, 2019 11:49 am
Where were these threads used?
Post by DanTreace » Thu Nov 14, 2019 11:55 am
Rear axle clam shell, for the drive shaft roller bearing housing holes. Use the tap to clean the holes for the studs or the later cap screws.
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Post by Jeepbone1 » Thu Nov 14, 2019 12:47 pm
I’ll take one.
Brad
Last Name: Hatch
Post by Dan Hatch » Thu Nov 14, 2019 3:52 pm
Needing at least 12 orders before I can get info. Dan
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Thu Nov 14, 2019 4:03 pm
I'll also take one.
sweet23
First Name: Darryl
Last Name: Bobzin
Post by sweet23 » Thu Nov 14, 2019 4:23 pm
I will take one too !
pre15dale
First Name: Dale
Last Name: Kemmerer
* REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Post by pre15dale » Thu Nov 14, 2019 4:46 pm
I will take one also. Dale
reolds
First Name: Gary
Last Name: Bausch
* REQUIRED* Type and Year of Model Ts owned: 1925 Speedster, 1923 TT w/Fabco frame conversion
Post by reolds » Thu Nov 14, 2019 10:03 pm
I will take one also Dan. Gary Bausch
Graybeard77
First Name: Clyde
Last Name: Gibson
* REQUIRED* Type and Year of Model Ts owned: 1926 Fordor Sedan, 1926 Roadster
Post by Graybeard77 » Thu Nov 14, 2019 10:15 pm
Graybeard77
First Name: Clyde
Last Name: Gibson
Post by Graybeard77 » Thu Nov 14, 2019 10:16 pm
I will take one also. Clyde Gibson
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Fri Nov 15, 2019 12:37 am
I also. Ken Buhler
Work honestly
Stay true to your word
Get the job done right
HalSched
First Name: Hal
Last Name: Schedler
* REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Post by HalSched » Fri Nov 15, 2019 1:36 am
I'll take one also. It would be nice to get a ball-park on $$
Last Name: Hatch
Post by Dan Hatch » Fri Nov 15, 2019 6:28 am
This only to find out if there is interest in making them. If there is enough interest I will see what the cost will be. I will let you know price before I make them so I will know if you want one. I will get back as soon as I know price. Thanks Dan
Bill Anziani
First Name: Bill
Last Name: Anziani
Post by Bill Anziani » Fri Nov 15, 2019 6:41 am
I would be interested as well
John bevardos
Last Name: bevardos
* REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
Post by John bevardos » Fri Nov 15, 2019 9:24 am
me too....
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Fri Nov 15, 2019 9:28 am
Super Mario Bross ;)
1911 Touring
1914 Speedster
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Fri Nov 15, 2019 9:29 am
Also if you have taste to do a tap for petcock it will be nice too.
1911 Touring
1914 Speedster
jab35
Last Name: Bartsch
Post by jab35 » Fri Nov 15, 2019 11:13 am
Dan I am interested if the price is under $20. jab35<at>cornell(dot)edu Thanks for making the offer, jb
Post by DanTreace » Fri Nov 15, 2019 11:22 am
Mario
A tap for the petcock thread in the crankcase or radiator lower tank is a simple 1/8" NPT (National Pipe Thread) -USA, 4-flute tap. In the US, a $3-6 common item, inexpensive.
Caution to not tap too deep at all, use care. This tap is taper thread, like modern pipe threads are, to allow a petcock to seat and seal. But Ford crankcase and old radiator petcock holes threads are just a tad different than modern, if you tap too hard, the taper threads can enlarge and the petcock might seep. Many old crankcase petcock holes have been compromised with modern taps.
Last Name: Hatch
Post by Dan Hatch » Fri Nov 15, 2019 11:28 am
I do not have a price yet, but you can be sure it will not be under $20.00. Dan
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Sat Nov 16, 2019 10:18 am
Thank you Dan for the advice. Really appreciated it
1911 Touring
1914 Speedster
Scott C.
Last Name: Clements
Post by Scott C. » Sat Nov 16, 2019 11:33 am
Wouldn't that make the correct pipe tap a 1/8" x 27 NPS tap and not a NPT tap? NPT is tapered while NPS is straight threads. NPS taps are readily available.
I would be interested in a 13/32" X 16 tap also.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sat Nov 16, 2019 1:52 pm
I would be in for one
pre15dale
First Name: Dale
Last Name: Kemmerer
Post by pre15dale » Sun Nov 17, 2019 11:17 am
Bump
nsbrassnut
First Name: Jeff
Last Name: Lee
Post by nsbrassnut » Sun Nov 17, 2019 7:08 pm
Hi Dan
I'd be interested in one too, if you are OK with mailing to Canada.
Jeff
Nova Scotia
TLeroux
Last Name: Leroux
Board Member Since: 2010
Post by TLeroux » Sun Nov 17, 2019 9:18 pm
I will also take one
tom leroux
Ken Buhler
First Name: Ken
Last Name: Buhler
Post by Ken Buhler » Thu Nov 21, 2019 1:10 am
James,
We can't tell the supplier what they should sell it for. I think that if you can't afford the part, do without unless you can provide a better part for less. We need to turn this hobby from cheap to fair.
Ken Buhler
Work honestly
Philip Lawrence
First Name: Philip
Last Name: Lawrence
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
Board Member Since: 2014
Post by Philip Lawrence » Thu Nov 21, 2019 8:19 am
Dan, I would be interested in one also.
Last Name: Hatch
Post by Dan Hatch » Thu Nov 21, 2019 10:55 am
Working on price. Will let you know what I come up with. Thanks Dan
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Thu Nov 21, 2019 11:00 am
James,
Ken Buhler
It doesn’t appear that James was suggesting what the price should be, but merely what he would be willing to pay. Since no indication of price had been mentioned, I think that his comment was appropriate.
Keep crankin’
Eric
Post by Mark Gregush » Thu Nov 21, 2019 11:04 am
The petcocks are pipe thread not straight thread. Sorry for thread drift. :D
