FS Front Lowering Bracket Kit
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Nov 16, 2019 5:23 pm
Ready to go, $175.00 shipped to your door. Email if interested. Only two left!
All the Best,
Model T Tom
First Name: Thomas
Last Name: Butterworth
* REQUIRED* Type and Year of Model Ts owned: 1911 speedster
Re: FS Front Lowering Bracket Kit
Post by Model T Tom » Sat Nov 16, 2019 5:33 pm
Looks a little thin for a suicide front end set up . but will work for stock T set up .
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Nov 16, 2019 5:35 pm
Well, it is made from 4400 series steel so thinner is a ok!
Jonathan.2909
First Name: Jonathan
Last Name: Sinclair
* REQUIRED* Type and Year of Model Ts owned: 1919 T runabout
Board Member Since: 2023
Post by Jonathan.2909 » Fri Jul 26, 2024 8:19 am
Hi, I know that it’s an old thread but I have a question as I am building my first T and Speedster. It looks to be a piece of billet aluminum or steel in the lower mounting bracket right under where the crank goes, what’s that for and do you have any available still?
Post by Jerry VanOoteghem » Fri Jul 26, 2024 8:53 am
Henry no longer participates on this forum. I believe the hunk of steel/aluminum is only there as a temporary filler piece used to hold everything in place for the photo.
He might still get an email if you send it through the forum "contact" icon.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Jul 26, 2024 10:33 am
Hi Johnathan,
That piece fits inside the front cross member
To support it so it will not collapse because there is no spring in the U part of the cross member with the lowering bracket installed. I you go to north west vintage speedsters web site there is a section on lowering speedsters you will find detailed drawing of some of these lowering mounts along with many other ideas.
Post by TRDxB2 » Fri Jul 26, 2024 11:25 am
All the Best,
all gone
