Brackets for top saddle support arms
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Post by tom_strickling » Sat Nov 16, 2019 5:43 pm
A friend is working on a 23 touring car. The brackets that you bolt the top saddle support arms into are missing. I have a set from a 21 touring. Can anyone tell me if these brackets are the same in 1921 and 1923?
IT IS THE BRACKET THAT THIS
https://www.macsautoparts.com/ford_mode ... lsrc=aw.ds
PLUGS IN TO.
THANKS TOM
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
Last Name: Strange
Re: Brackets for top saddle support arms
Post by CudaMan » Sat Nov 16, 2019 6:40 pm
Looking in Bruce's book, wouldn't a 1923 have had the holes in the rear of the body for the straight top saddle support arms to poke through?
https://www.modeltford.com/item/3858B.aspx
Post by John kuehn » Sat Nov 16, 2019 7:51 pm
Does your 23 have the brackets going over the body or through it. The earlier Touring 22 and back, had the brackets going over the body while the later Touring had the bracket (or arm) going through the body. The earlier Tourings had a 5 piece back section. The later Tourings had a 3 piece back which had the arms going THROUGH the body. Hope this helps.
Post by Original Smith » Sun Nov 17, 2019 10:05 am
Don't forget, the L arms and the straight through top saddle rods use different top saddles.
Hap_Tucker
First Name: Hap
Last Name: Tucker
Post by Hap_Tucker » Mon Nov 18, 2019 7:04 am
Tom,
Thank you so much for helping your friend with his T. With over 15,000,000 made and many of them modified to keep them in service over the years we all have questions about some part etc.
Photos below should help you see what folks above have been talking about with the earlier style verses later style touring bodies and how the top rest was changed from the old style to the new style. From the factory, both styles were offered with a lot of overlap. And depending on the source you will see the year listed a little differently for when the change occurred. But which ever style body your friend has, that is the style top rest that would have come with that body.
Caution -- if the body was rebuilt, you can mix and match different parts from an earlier body and a later body and come up with one that Ford never originally supplied, but that still functions "OK."
And of course are you sure it is a 1923 T? Engines, bodies, etc.may have been swapped out over the years.
I hope the illustrations below are of some help to you.
1915-1921-ish
1915-1921-ish
1921-ish to  1925
1921-ish to 1925
Good luck and again thank you for helping a friend with his T.
Respectfully submitted,
Hap l9l5 cut off
tom_strickling
Post by tom_strickling » Mon Nov 18, 2019 6:05 pm
Thank you one and all. Excellent information.
