Tail Lite Wiring
dunoon
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Tail Lite Wiring
Post by dunoon » Thu Nov 28, 2019 10:08 am
I'm going to be adding an additional wire to my tail-lights on my 26 coupe for the brake light. Does anyone know of a loom or sleeve that I could use for these wires or should I just wrap them with friction tape. Thanks
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Tail Lite Wiring
Post by Humblej » Thu Nov 28, 2019 10:33 am
Ford Service Bulletin says to tape the two wires together in several places. I choose to twist/braid the two wires together like the horn and coil box wires are done.
Dave Young
First Name: David
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: 26 Touring, 26 RPU, 24 Coupe, 26 Speedster, 28 Chandler, 29 Chandler, 29 A
Post by Dave Young » Thu Nov 28, 2019 11:03 am
For a nice, neat appearance, I use asphalt-coated cloth loom for all of my wiring work and tie it to others with Dacron fishing line any place where the loom is visible.
Post by Original Smith » Thu Nov 28, 2019 11:22 am
I used friction tape, which is period correct. Read the above comment.
Last Name: Hjortnaes
Post by DHort » Thu Nov 28, 2019 11:23 am
www.restorationspecialties.com
You can buy loom by the foot.
