How do you separate two transmission drums?
shirleysboy
First Name: Marvin
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 1914
Post by shirleysboy » Mon Dec 09, 2019 5:47 pm
Do you use a press to press out the big gear? One drum is cracked. Thanks
Re: How do you separate two transmission drums?
Post by Scott_Conger » Mon Dec 09, 2019 6:00 pm
Marvin
those drums should just slide apart. If they don't, they are likely wedged together from bead/sand blast media, assuming from the photo that they were in fact blasted. If that is the case then that media may be permanently embedded into the bushings and render them useless, which would be too bad (bushings rarely wear out and ought to be used as-is wherever possible). Glass beads will scar the bushings as they come apart but not embed to any extent, while AL-OX or any other media will most certainly embed.
kevinf
First Name: Kevin
Last Name: Fielding
Post by kevinf » Mon Dec 09, 2019 6:12 pm
Marvin,
As was mentioned it should just slide apart. Check the teeth on the gear sometimes they get a bit of a burr on them and that will keep them from coming apart. Hope that makes sense.
Best of luck,
Kevin
shirleysboy
First Name: Marvin
Last Name: Miller
Post by shirleysboy » Mon Dec 09, 2019 6:39 pm
Thank you guys. I will see if they come apart.
Marv.
Post by John kuehn » Mon Dec 09, 2019 7:00 pm
Use some type of lube to help them to turn. Light oil, WD-40 etc.
When they begin to turn take your time and they should separate.
Can you tell if they is a ridge on the gear or bushing?
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Mon Dec 09, 2019 10:08 pm
As they said earlier check the gear, I will take a flat file on the outside of the gear to knock the burr's off when you look at the low speed drum some will have a groove cut into the gear if lots of use.
rickg
Last Name: Goelz
* REQUIRED* Type and Year of Model Ts owned: 1924 Fordor, 1926 Coupe, 1923 popcorn Truck
Post by rickg » Wed Dec 11, 2019 7:06 pm
Wear gloves as those things can bite.
Rick
