Coil tester
Model t tommy
Last Name: anderson
Coil tester
Post by Model t tommy » Tue Jan 29, 2019 4:23 pm
does anyone have any information on this tester
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Coil tester
Post by BE_ZERO_BE » Tue Jan 29, 2019 7:42 pm
This is a Ford 17-Z-803 Tester.
It is the predecessor to the 18-Z-245 Coil Tester.
Respectfully Submitted,
Be_Zero_Be
Ruxstel24
Last Name: Hanlon
Re: Coil tester
Post by Ruxstel24 » Tue Jan 29, 2019 8:07 pm
I knew Bob would know. :)
Model t tommy
Last Name: anderson
Re: Coil tester
Post by Model t tommy » Tue Jan 29, 2019 8:53 pm
Thanks for the info. As always Tom
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Coil tester
Post by BE_ZERO_BE » Tue Jan 29, 2019 9:55 pm
I learned what I know about HCCTs from Ron Paterson :D
Be_Zero_Be
Re: Coil tester
Post by Original Smith » Fri Feb 01, 2019 11:03 am
I don't know how a Model T owner can be without one. I use mine frequently for myself and others.
Tom Hicks
First Name: Thomas
Last Name: Hicks
* REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
Re: Coil tester
Post by Tom Hicks » Fri Feb 01, 2019 11:39 am
The HCCT works well, but it is not the only girl in town. I have found the ECCT to be very accurate, and probably lower in cost.
Re: Coil tester
Post by Steve Jelf » Fri Feb 01, 2019 11:50 am
...and probably lower in cost
The ECCT is about half the usual cost of the HCCT, and so is the Strobo Spark.
Ruxstel24
Last Name: Hanlon
Re: Coil tester
Post by Ruxstel24 » Fri Feb 01, 2019 12:19 pm
Along with my Allen HCCT, I have several different ECCTs, both 6V and 110V AC...
I prefer the HCCT, but run a distributor, so it rarely gets used.
Ruxstel24
Last Name: Hanlon
Re: Coil tester
Post by Ruxstel24 » Sat Feb 02, 2019 12:42 pm
Here's a couple ECCTs, one DC and one is AC.
Sorry bout the glare, sunshine ! 8-)
There's a homemade one that holds 4 coils, but the picture didn't come out.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Coil tester
Post by BE_ZERO_BE » Sat Feb 02, 2019 12:48 pm
Here are some interesting things that I discovered about the Jefferson Model 28 Coil Tester.
viewtopic.php?f=2&t=269&p=1586&hilit=jefferson#p1586
Be_Zero_Be
Ruxstel24
Last Name: Hanlon
Re: Coil tester
Post by Ruxstel24 » Sat Feb 02, 2019 12:49 pm
And my Allen tester :)
Ruxstel24
Last Name: Hanlon
Re: Coil tester
Post by Ruxstel24 » Sat Feb 02, 2019 12:51 pm
Appears to be the one on the wall is a Jefferson.
Thanks Bob ;)
HalSched
First Name: Hal
Last Name: Schedler
* REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Re: Coil tester
Post by HalSched » Sat Feb 02, 2019 5:02 pm
I gave one of the Jefferson #28 testors to the Museum. I hope they still have it
Doug Keppler
First Name: Douglas
Last Name: Keppler
Re: Coil tester
Post by Doug Keppler » Sat Feb 02, 2019 8:09 pm
Dave, with all due respect I believe the ECCT is the Electronic Cranked Coil Tester as designed and sold by Mike Kosser www.modeltecct.com
1924 Touring car
There's No Substitute for Proper Lubrication
Ruxstel24
Last Name: Hanlon
Re: Coil tester
Post by Ruxstel24 » Sat Feb 02, 2019 8:35 pm
Pardon my ignorance, what should I call a non hand cranked tester.
No offense to Mike was intended. :)
Doug Keppler
First Name: Douglas
Last Name: Keppler
Re: Coil tester
Post by Doug Keppler » Sat Feb 02, 2019 10:20 pm
It's probably a buzz box coil tester which most likely only tests the primary and secondary coils to tell you if they are good
1924 Touring car
