Spiral Tube Radiator.
Post by Rich Eagle » Wed Dec 18, 2019 11:56 am
While looking for some KD info I stumbled across this. I had not seen it before.
HPetrino
First Name: Henry
Last Name: Petrino
Re: Spiral Tube Radiator.
Post by HPetrino » Wed Dec 18, 2019 12:17 pm
Interesting item. I wonder why they marketed it as for a TT when, as we all know, if it fit a TT it would fit a regular T. Also interesting is that they marketed a "Type B" for 1917-21 trucks (obviously low radiator models) and a "Type A" for 1913-16 models. Somebody was confused.
Thanks for posting this.
Last Name: Seth
Post by perry kete » Wed Dec 18, 2019 12:42 pm
I would hazard a guess that they singled out trucks in that ad because it was published in "The Commercial Motor" magazine
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Dec 18, 2019 1:11 pm
I bet the aluminum tanks all corroded out in a couple years and there are none left!
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Wed Dec 18, 2019 2:51 pm
"All Parts Machined to Jigs and Interchangeable"
In England ? You gotta be kidding me. They should have sold the concept to Rolls Royce !
Tiger Tim
Last Name: Eckensviller
* REQUIRED* Type and Year of Model Ts owned: 1926 cut-off touring
Post by Tiger Tim » Thu Dec 19, 2019 12:28 pm
It’s a quiet way to admit it’s ugly.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Thu Dec 19, 2019 6:49 pm
1913-1916 are the flat sided radiators, 1917+ are the rounded-side radiators.
They remind me of something from the front of a tractor. It IS a nifty idea, tho... if the tubes had rubber o ring seals,to and the tank was also sealed to the top of the able to be removed or installed not with a soldering iron but by removing bolts to separate it from the bottom half... You take the tank off, pull the bad tubes out, put the new ones in, ake sure the rubber gasket for the tank is still good, and reattach the top tank.
