Dubatt's crank
Topic author - Posts: 1183
- First Name: Joe
- Last Name: Bell
Dubatt's crank
I had not installed one in several years but I have to say it sure is nice not having to deal with grinding or cutting the horse shoe for the inspection pan, that tad more clearance is great!
- Last Name: van Ekeren
Re: Dubatt's crank
I wish that scat would shave a bit off the diameter, would make life a lot easier to fit
- First Name: Walter
- Last Name: Higgins
- * REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
Re: Dubatt's crank
Are there any interference issues with a Scat in a one-piece pan?
- First Name: Joe
- Last Name: Bell
Re: Dubatt's crank
Walter, never done one so I can not answer that one on the one peice pan???
- First Name: Dale
- Last Name: Peterson
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1916 Roadster, 1925 Roadster PU, 1926 Canadian Fordor, 1927 Speedster
Re: Dubatt's crank
No clearance problems with the Scat crank installed in my Canadian 26 Foredoor last year.
Re: Dubatt's crank
I,m surprised at that Dale.
- First Name: Herman
- Last Name: Kohnke
- * REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Re: Dubatt's crank
We never had a problems with all the Scat cranks we put in. About 78 to date.
The only thing that could make some off, is if the line bore Guy didn't know how to line bore, and get them always off center.
Herm.
Herm.
Re: Dubatt's crank
Herm, sounds like out of 78 scats you never had to fit any of the pans
- First Name: Joe
- Last Name: Bell
Re: Dubatt's crank
Kerry, I was thinking the same thing, I for got once and bolted it on, found out real quick when I turned it over the first time!
- Last Name: Kohnke
Re: Dubatt's crank
We use 26-27 pans, in all engines!
Herm.
Herm.
- First Name: Bill
- Last Name: Hoffer
Re: Dubatt's crank
So Herm, if a guy had an early engine and wanted to keep all the visible stuff original to the year in question, you couldn't help him out? You would not build with an early pan? Question asked with the greatest respect, Bill
- Last Name: Kohnke
Re: Dubatt's crank
I have never had that come up. Normally, after I explain the advantages of a 4 Dip, that's what they want. But if they don't, normally again, they don't want anything, but a Ford crank. If we do use the 26-27 pan, they keep their original pan, with the car.
I know all you Guys Grind the Horse shoes, but i take it off the crank, I just don't like to refit the good parts to the problem parts.
We used to build counter, weighted cranks for the Model A's, the O. D. is the same. Here is a picture of our crank.
Herm.
- First Name: Gene
- Last Name: Carrothers
Re: Dubatt's crank
I have a DuBats crank in my '12 with an early pan and would not ever change it out for a later one! That Narrow nose adds a minimum of 2 miles per hour!
1912 Torpedo Roadster
