13 pinnion gear
Rich Huggins
First Name: Rich
Last Name: Huggins
* REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
13 pinnion gear
Post by Rich Huggins » Mon Dec 30, 2019 1:32 pm
high gear ratio 13 tooth pinnion install on 40 tooth stock ring gear can i do it 1923 t touring 3speed bg warnner t 90 trans
Ruxstel24
Last Name: Hanlon
Re: 13 pinnion gear
Post by Ruxstel24 » Mon Dec 30, 2019 1:46 pm
You can use a 40 tooth gear with a 13 tooth pinion, but not a stock ring gear.
It has to be recessed on the backside to position it to the left a little, to be able to get the proper depth of the pinion. 3.076 is the ratio.
Rich Huggins
First Name: Rich
Last Name: Huggins
Re: 13 pinnion gear
Post by Rich Huggins » Tue Dec 31, 2019 3:42 am
Were do i find the proper ring gear 40 tooth with recess
