Dave,
Great photo.
Note if you zoom in on it you can see that it is a cut off touring with the door jam visible at the back of the front seat. You can also see the head of the bolt in the side of the body that holds the back of the front seat frame and body together.
The windshield bracket is for the starter equipped open cars -- so mid 1919 to 1922. In 1923 model year they went to the slanted windshield. ref:
https://www.mtfca.com/encyclo/doc19.htm
APR 30, 1919 Acc. 575, Box 11, #732, Ford Archives
T-7845, 7846 windshield bracket with integral side lamp bracket used on open cars without starter only. T-7845B and T-7846B bracket used with starter cars (has no oil lamp bracket).
It still has the wider arm rest with the wider metal cap -- used very late 1916-to 1921 on the tourings and a little later on the Runabouts/Roadsters. The later 1921 to 1925 tourings used the narrower arm rest along with the 3 piece rear touring seat tub.
- Arm rest wide 1917-1921ish tourings.jpg (15.72 KiB) Viewed 3699 times
If you have some additional photos of the car -- we might be able to narrow down the year range a little. But based on those observations later 1919 to 1921. And many of the 1919 to 1921 open cars look about the same.
Again -- great photo with hopefully some great memories for you!
Respectfully submitted,
Hap l9l5 cut off
