Valve timing
Dennis_Brown
Topic author - Posts: 274
- First Name: Dennis
- Last Name: Brown
Valve timing
Does it do any good to check valve timing with the head on other than to see if anything has changed? Unless one has adjustable lifters, no adjustments could be made. Just running things thru my mind.
