Transmission safety wire
Wilbur
Topic author - Posts: 11
- First Name: Wilbur
- Last Name: Swearingin
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout 1923 Coupe 1924 Tudor 1926 Pickup
Helping a friend with a nice TT truck. Doing primary inspection noticed someone in remote past safety wired transmission with stranded copper. Well it probably long ago broke and was hanging loose. Pulled it out with my fingers. Has anyone tried putting the safety wire in through the trans door. Looks like should be able to. Any advice would be welcome.
Re: Transmission safety wire
Are you referring to the driven plate bolt(s) wire ?
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
The only hardware you can reach thru the transmission inspection cover is the 6 driven plate bolts, and the clutch finger screws.
The driven plate bolts can be wired thru the cover (suggest wiring in pairs). The clutch finger screws take cotter pins, and also can be done thru the access cover
Wilbur
Yes the driven plate bolts. Plan to wire together in pairs.
- Last Name: Strange
- Board Member Since: 2013
After they've been checked for tightness, right?
Kaiser
- First Name: Leo
- Last Name: van Stirum
You could ask your wifes gyneacologist to do it
Leo van Stirum, Netherlands
Would like to see how he'd get it up on the table...
