nh carb needle and seat
bobt
Topic author - Posts: 302
- First Name: Robert
- Last Name: Thompson
Does anyone know a part number for a NH carb viton tipped needle and seat? thanks, bobt
Re: nh carb needle and seat
The Part Number at regular suppliers is: 6212
That part is made with an orifice that is smaller than original, by a sizeable margin. It is fine for driving where high speeds are not sustained, or long hard hills are encountered. If either of those two conditions will be met by you, then you may want a version of that valve which has the correct sized orifice and is designed to flow a larger amount of fuel, quicker, to avoid fuel starvation. See: https://www.mtfca.com/phpBB3/viewtopic. ... low#p70695
