Broken global repairman?
csnailnrun
First Name: Ryan
Last Name: Snellen
* REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
Post by csnailnrun » Fri Jan 24, 2020 11:26 am
I'm in Nashville looking for a glass globe repairman. I was pouring packing peanuts over a glass globe I've had in a box for two years and a T part poured over on the globe and broke it. I should have left the damn thing unpacked being it's been safe for the past two years that way! There are a few small pieces the size of a half dollar coin with the other three larger chunks.
Anyhow, any recommendations would be appreciated. It's worth a phone call to a repairman to inquire on the cost.
RichardG
Last Name: Grzegorowicz
* REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
Re: Broken global repairman?
Post by RichardG » Fri Jan 24, 2020 12:12 pm
RYAN, KNOW JUST HOW YOU FEEL, A FEW YEARS BACK I WAS GIVEN A DOG BONE RADIATOR CAP WITH A SMALL WORKING MOTOR METER , IT WAS WRAPPED IN A CLOTH ON MY BENCH, KINDA FORGOT IT WAS THERE, SIGH, I NEEDED A RAG QUICK, YUP ON THE FLOOR WITH A CRASH, I KNEW AS SOON AS I SWUNG THE RAG WHAT I DID, BUT JUST STOOD THERE AND WATCHED THAT LITTLE TREASURE SMASH TO THE FLOOR, WHAT I WOULD GIVE TO HAVE IT TO PUT ON MY MODEL T , GOOD LUCK FINDING YOUR MAN.
Post by Steve Jelf » Fri Jan 24, 2020 12:35 pm
Glass globe? Is that something on a Model T?
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Fri Jan 24, 2020 12:49 pm
Glass globes for fuel pumps.
Thanks for having me clarify.
Post by John kuehn » Fri Jan 24, 2020 2:43 pm
Do you know what kind of fuel pump it is or is it real rare? Old tractors and gas tanks used glass bowls in their fuel system. Might be something to check to see if they would be close to identical.
Post by DanTreace » Fri Jan 24, 2020 3:20 pm
Think John means this type of globe.
IMO, all you can do now is patch it back with super glue. Humpty Dumpty got broke :( :o
Post by Steve Jelf » Fri Jan 24, 2020 3:34 pm
So we're talking about one of these. I would start at TSC, Orscheln, Fleet & Farm, etc. Whatever your local farm supply is. Maybe Napa, O'Reilly, etc., but I doubt it. You may have to order online. Google glass bowl fuel filter.
Post by John kuehn » Fri Jan 24, 2020 3:59 pm
Whichever one it is hope you can repair it.
We repaired a fairly rare Avon bottle with super glue and it does work. Maybe there are other types of glue that’s good for glass repair. Good luck.
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Fri Jan 24, 2020 4:11 pm
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Fri Jan 24, 2020 4:14 pm
I bought this from Bill Houston 2 yrs ago. Looking at it makes me sick that the dumb bolt was left in the packing peanuts and broke it. I believe
Fred or someone hand painted it themselves.
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Post by Mustang1964s » Fri Jan 24, 2020 4:20 pm
Now that could make a grown man cry.
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Jan 24, 2020 5:27 pm
I’d say you are SOL Ryan, I just this afternoon broke a 120 year old piece of beveled glass in a coin op machine. I know the sick stomach you have, you will get over it never !
BuddyTheRoadster
First Name: Chris
Last Name: Rini
* REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Post by BuddyTheRoadster » Sat Jan 25, 2020 2:27 pm
Oh that does suck. If glued, the cracks will still show when lit. Your best bet might be to look for a milk glass or opal lamp shade or lamp globe and then get the Ford script painted or stenciled on. Good luck!
HalSched
First Name: Hal
Last Name: Schedler
* REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Post by HalSched » Sat Jan 25, 2020 2:41 pm
Here's a long shot: Get a white baloon and blow it up inside the globe just tight enough to be the shape of the globe and use some UV glue to put it back togeather. I get the Ultra 'Violet glue at my ACE Hardware store. If it works fine. If it dosen't at least U tried.
Terry_007
First Name: Terry
Last Name: Bond
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Chassis
Post by Terry_007 » Sat Jan 25, 2020 4:49 pm
Is that a repro? Don't believe I've ever seen anything like that before that was original. Could be wrong so please tell me more -
Thanks,
Terry
Post by DanTreace » Sun Jan 26, 2020 9:34 am
This reproduction visible fuel pump globe took a break too. Appears owner fixed it with glue, but as posted, you can see the repairs.
dlmyers
First Name: Dale
Last Name: Myers
Post by dlmyers » Sun Jan 26, 2020 11:49 am
If you can see the glue lines after you put it back together you could paint more lines on the globe to make it look like crazing which is common in old pottery.
The old forums are a gold mine of information.
