brought home a Extreme rust bucket!
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Wed Nov 12, 2025 2:12 pm
Well, here is my latest bring home item.
M37 remnants
Will probably resell at some point but i just literally saved it from going to the junk man, still has the transfer case and such. Extremely rusty ,frame stretched,
Re: brought home a Extreme rust bucket!
Post by TXGOAT2 » Wed Nov 12, 2025 6:48 pm
A lot of that thing could be rebuilt with flat sheet metal. A little rough sheet metal looks just fine under flat olive drab.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Tue Nov 18, 2025 9:10 pm
Cool find! We saved a closed cab cckw that a guy wanted for the fenders and scrap the rest. It has a chopped frame, 4 instead of 6 wheels, and a manure spreader on it- which is rusted out, and the truck isnt much better. We also saved a neat rusted hobart welder and generator from the 40s. We saw an old rock crusher being chopped up for scrap and a lot of old neat farm equipment along with it. :(
The former owner was crying when she found out what was happening to most of the things after the auction.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Wed Nov 19, 2025 8:21 pm
I got all the trash cleaned off the back of it, and accessed it a bit the other day. hood had a solid sheet of fiberglass on it, alot of bondo in the corners, and the entire top of the cowl is gone,what's there is a bolted on piece of sheet metal.
I have since located, a mile down the road, a 49 power wagon that will sadly be stripped for it's body to go on a 2005 dodge chassis. i want to stay connected with the fellow because the engine is similar enough to fit this.When i first decided to try to save this, i didn't know it was quite so rusty. but my plan originally was to put a 300 ci inline ford 6 cylinder in it. still might,aint gave up. thinking of selling was a first impulse after finding all the rust.
And it was a Air force truck, so blue would be it's correct color.
[/quote]
Post by TXGOAT2 » Thu Nov 20, 2025 10:58 am
You couldn't pay me to cut up a real Power Wagon. I might go as far as putting a Cummins engine in one, but I wouldn't molest a good original even to do that. I think the Dodge flathead sixes will interchange across a wide range of years. There are truck versions with more displacement and torque than the ones in most cars. A Chrylser six marine/industrial engine might be a close fit. I used to see 1970s and early 1980s pickup-based Power Wagons on the road in a flat olive drab and in a flat Air Force medium blue. I never see the National Guard or Air Force guys out on the roads on weekends anymore. A Ford 300 with a five speed behind it would be a good choice.
