I am looking for someone who could repair a small crack in the rear exhaust port of a 1909 Part Number T511 Manifold. See attached photos. Please reply to my email or on the forum.
Thanks Daniel Snell[/size][/b]
Exhaust Manifold Repair
SurveyKing
Topic author - Posts: 509
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Re: Exhaust Manifold Repair
Daniel, being that you are in the San Antone area, I would think you are in Pipeline welder country. Research a product called Muggy Weld 77. I use it to weld cast iron blocks, etc. While it is relatively a low heat welding rod, I would still have a heat blanket or a bucket of sand to let it cool in. A Needle Scaler will be helpful, and most pipeline guys should have that.
