Exhaust Manifold Repair
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Sat Feb 14, 2026 10:12 pm
I am looking for someone who could repair a small crack in the rear exhaust port of a 1909 Part Number T511 Manifold. See attached photos. Please reply to my email or on the forum.
Thanks Daniel Snell
[/size][/b]
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Re: Exhaust Manifold Repair
Post by BRENT in 10-uh-C » Sun Feb 22, 2026 7:01 pm
Daniel, being that you are in the San Antone area, I would think you are in Pipeline welder country. Research a product called Muggy Weld 77. I use it to weld cast iron blocks, etc. While it is relatively a low heat welding rod, I would still have a heat blanket or a bucket of sand to let it cool in. A Needle Scaler will be helpful, and most pipeline guys should have that.
