Post by Scott_Conger » Mon Jul 05, 2021 9:54 pm
NH Full Flow Float valves in stock
No more obsolete parts being made for sale. Only new NH Full Flow Valves are in production.
Last of these kinds of parts are now gone:
Mark Nunn
Last Name: Nunn
Re: NH Full Flow Float Valves and Obsolete Carb parts - this job is done
Post by Mark Nunn » Thu Jul 08, 2021 7:30 am
Scott, after installing your float valve in my '26 I opened my tank's fuel valve. I didn't hear the normal tinkle sound of fuel entering the carb bowl. I thought I had an obstruction of some sort. It turns out that the fuel flowed in a stream instead of a dribble. I've only driven 10 miles since then because I'm still chasing some front axle problems so I don't have an objective evaluation yet.
JWalters
First Name: Jason
Last Name: Walters
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by JWalters » Wed Sep 29, 2021 6:24 pm
Bump to top
FreighTer Jim
Last Name: Jarzabek
Board Member Since: 2008
Post by FreighTer Jim » Sat Oct 09, 2021 6:27 pm
Bump ….
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Thu Mar 10, 2022 9:05 am
To the top for a guy making a great part for the hobby.
Post by Scott_Conger » Wed Apr 20, 2022 5:07 pm
Stromberg OF parts:
Idle Jets
Choke Springs
Economizer Valve
Economizer Lever Pivot
Adjuster Well
Quickm007
First Name: Mario
Last Name: Brossard
Re: NH Full Flow Float Valves and Obsolete Carb parts manufactured
Post by Quickm007 » Thu Apr 21, 2022 9:37 am
Impressive Scott!
Super Mario Bross ;)
1911 Touring
1914 Speedster
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
* REQUIRED* Type and Year of Model Ts owned: 1916 TOURING
Post by BE_ZERO_BE » Fri Apr 22, 2022 11:36 am
That is true A.S.N. quality !! (At-Sa-Nicea) :lol:
Respectfully Submitted,
Be_Zero_Be
I drive a Model T ... Microseconds don't matter :D
Post by Scott_Conger » Tue Jun 14, 2022 8:41 pm
Fuel inlet bolt and fitting for Zenith U6 for RAJO "B" copied from an original taken from it's little brother, a U5...serious ZOOMING to occur soon
TRZim
Last Name: Zimmer
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1914 touring 1915 speedster
Post by TRZim » Fri Sep 09, 2022 11:40 pm
You still have the NH enlarged seat for fuel pressure by the float to open and close? I bought one from you I now need another.
Re: NH Full Flow Float Valves now in stock, and Obsolete Carb parts manufactured.
Post by Scott_Conger » Sat Apr 22, 2023 11:03 pm
Fun stuff made this winter: Zenith S4BF jets and springs
Post by Scott_Conger » Sat Apr 22, 2023 11:16 pm
specialty work requires specialty tools (now you know why there's a notch in the mounting flange):
