NH Full Flow Float valves in stock
No more obsolete parts being made for sale. Only new NH Full Flow Valves are in production.
Last of these kinds of parts are now gone:
Mark Nunn
- Last Name: Nunn
Re: NH Full Flow Float Valves and Obsolete Carb parts - this job is done
Scott, after installing your float valve in my '26 I opened my tank's fuel valve.  I didn't hear the normal tinkle sound of fuel entering the carb bowl.  I thought I had an obstruction of some sort.  It turns out that the fuel flowed in a stream instead of a dribble.  I've only driven 10 miles since then because I'm still chasing some front axle problems so I don't have an objective evaluation yet.
FreighTer Jim
- Last Name: Jarzabek
- Board Member Since: 2008
Bump ….
FJ
									FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
- First Name: Dallas
- Last Name: Landers
To the top for a guy making a great part for the hobby.
Stromberg OF parts:
Idle Jets
Choke Springs
Economizer Valve
Economizer Lever Pivot
Adjuster Well
									Idle Jets
Choke Springs
Economizer Valve
Adjuster Well
Quickm007
- First Name: Mario
- Last Name: Brossard
Re: NH Full Flow Float Valves and Obsolete Carb parts manufactured
Impressive Scott!
									Super Mario Bross
1911 Touring
1914 Speedster
 1911 Touring
1914 Speedster
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
That is true A.S.N. quality !! (At-Sa-Nicea)
Respectfully Submitted,
Be_Zero_Be
						Be_Zero_Be
Fuel inlet bolt and fitting for Zenith U6 for RAJO "B" copied from an original taken from it's little brother, a U5...serious ZOOMING to occur soon
				TRZim
- First Name: Tom
- Last Name: Zimmer
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1914 touring 1915 speedster
You still have the NH enlarged seat for fuel pressure by the float to open and close? I bought one from you I now need another.
Re: NH Full Flow Float Valves now in stock, and Obsolete Carb parts manufactured.
Fun stuff made this winter: Zenith S4BF jets and springs
specialty work requires specialty tools (now you know why there's a notch in the mounting flange):
