Speaking of cranking !
Rich Bingham
Topic author - Posts: 1942
- First Name: Rich
- Last Name: Bingham
Has anyone ever run onto a crank arrangement like this one ? Any thoughts ??
"Get a horse !"
HPetrino
- First Name: Henry
- Last Name: Petrino
Re: Speaking of cranking !
Really hard to tell, but upon enlarging it somewhat I'm thinking it's a spring loaded accessory. Wind up the spring, then release it to turn the engine over.
Of course, pure guess......
It appears to be a "Sandbo" hand starter.
R.V.Anderson
- First Name: R.V.
- Last Name: Anderson
Looks like he made the wife do the cranking. Hence the helmet and the missing RH headlamp...
Steve named it!
PDGx
- First Name: Paul
- Last Name: Grohsmeyer
Damm, need one of those for my Mack - with a 4’ vertical climb in and out every time
http://www.cimorelli.com/mtdl/1914/1914 ... tarter.pdf
However, I doubt you could pull a recoil starter on it - especially from the seat.
(I won’t ever complain about hand cranking a T again.)
Rich Bingham
- First Name: Rich
Pretty nifty ! Apparently you could crank it "conventionally" from outside the car too. I wonder if the device entailed an anti-kick device ? Caption on the photo says "Carey, Idaho, 1917".
"Get a horse !"
