***1914-1921 Drive Shaft Assembly***
- Last Name: Hjortnaes
Re: ***1914-1921 Drive Shaft Assembly***
2586 does not exist on my cars
please include bolts that go into 2583
Otherwise it all looks good.
The 2586 would have been used on all closed spool housings. It retains the pinion bearing sleeve. 1921 back would have used studs not bolts.
Edit re 2586;
Except the early housings that were babbitt.
Edit re 2586;
Last edited by Mark Gregush on Tue Aug 25, 2020 11:16 am, edited 2 times in total.
Since when does the cast iron housing use bolts? They use studs and castle nuts!
Topic author - Posts: 584
- First Name: Martynn
- Last Name: Vowell
- Board Member Since: 2012
Small change
The reason for this change was because to show the differences between the 1918 and 1919, I'd need to draw a completely new drawing for those small plugs that cover the pin holes for the U-Joint. Just didn't think it was worth it...so I made a notation instead.
Fun never quits!
Like everything else, do your research before posting on the forum!
- Last Name: Vowell
Larry, that's exactly WHY I do post to the forum. My research is limited, you guys know a hell of a lot more than I do, sooooooo, I post here, so you and everyone else can help to make them correct.
Fun never quits!
