13T - Body Number?
Topic author - Posts: 256
- First Name: Darin
- Last Name: Hull
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
- Board Member Since: 2010
13T - Body Number?
I don’t know how I missed this number until today. It is under the seat on the leading edge near the gas tank. Is there any worthwhile information to be gleaned from this?
Darin
Darin
- First Name: Keith
- Last Name: Townsend
Re: 13T - Body Number?
Darin-
The body was made by Beaudette. It is an inventory number for Beaudette, and not used for Ford records.
Look on the underside of the back doors. You may find the number there, too.
-Keith
-Keith
- First Name: Barry
- Last Name: Loucks
- * REQUIRED* Type and Year of Model Ts owned: 13, 22
Same here. Owned my 13T for 20 years just saw the body number about 2 weeks ago. Let’s see if the photo posts.
Barry
Barry
- First Name: Barry
- Last Name: Loucks
Mine is a Fisher body, as in “Body by Fisher” Canadian made.
- First Name: Barry
- Last Name: Loucks
- First Name: Darin
- Last Name: Hull
Keith,
I have a runabout. Looked under the only door I have and don’t see a number.
Darin
Darin
- First Name: Barry
- Last Name: Loucks
Pull up the seat cushion. The wooden piece that the seat sits on has the number. Mine was on the left hand side.
- First Name: Darin
- Last Name: Hull
Barry,
That’s where that first pic is from. Don’t know how I’ve missed it before.
Darin
Darin
- First Name: Barry
- Last Name: Loucks
What does the prefix ‘B’ stand for?
- First Name: Darin
- Last Name: Hull
Barry,
I inferred from Keith’s comment the b means the body was made by Beaudette.
Darin
Darin
Ford themselves did not build the bodies for their cars during the brass era. Pre-model T and first two years of model T, Wilson was one of if not the largest supplier of bodies to Ford. Wilson also supplied bodies to several other automobile manufacturers including Cadillac. By 1913, Beaudette was supplying more bodies for Ford's huge and growing demand, and remained one of if not the largest suppliers until the end of the brass era. There were about five other companies that built significant numbers of bodies for Ford during the brass era.
Ford began building bodies in house about 1917 or '18. However outside suppliers continued building some of the bodies clear though the end of model T production. The '24 coupe I used to have had a Fischer body.
- First Name: Darin
- Last Name: Hull
Wayne,
Solid quick history lesson. Thank you!
