13T - Body Number?
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
13T - Body Number?
Post by Darin Hull » Sat Sep 12, 2020 4:11 pm
I don’t know how I missed this number until today. It is under the seat on the leading edge near the gas tank. Is there any worthwhile information to be gleaned from this?
Darin
First Name: Keith
Last Name: Townsend
Re: 13T - Body Number?
Post by KWTownsend » Sat Sep 12, 2020 4:32 pm
Darin-
The body was made by Beaudette. It is an inventory number for Beaudette, and not used for Ford records.
Look on the underside of the back doors. You may find the number there, too.
-Keith
Barry Loucks
First Name: Barry
Last Name: Loucks
* REQUIRED* Type and Year of Model Ts owned: 13, 22
Post by Barry Loucks » Sat Sep 12, 2020 4:36 pm
Same here. Owned my 13T for 20 years just saw the body number about 2 weeks ago. Let’s see if the photo posts.
Barry
Barry Loucks
First Name: Barry
Last Name: Loucks
Post by Barry Loucks » Sat Sep 12, 2020 4:37 pm
Mine is a Fisher body, as in “Body by Fisher” Canadian made.
Barry Loucks
First Name: Barry
Last Name: Loucks
Post by Barry Loucks » Sat Sep 12, 2020 4:38 pm
Darin Hull
First Name: Darin
Last Name: Hull
Post by Darin Hull » Sat Sep 12, 2020 4:44 pm
Keith,
I have a runabout. Looked under the only door I have and don’t see a number.
Darin
Barry Loucks
First Name: Barry
Last Name: Loucks
Post by Barry Loucks » Sat Sep 12, 2020 5:21 pm
Pull up the seat cushion. The wooden piece that the seat sits on has the number. Mine was on the left hand side.
Darin Hull
First Name: Darin
Last Name: Hull
Post by Darin Hull » Sat Sep 12, 2020 6:36 pm
Barry,
That’s where that first pic is from. Don’t know how I’ve missed it before.
Darin
Barry Loucks
First Name: Barry
Last Name: Loucks
Post by Barry Loucks » Sun Sep 13, 2020 5:23 pm
What does the prefix ‘B’ stand for?
Darin Hull
First Name: Darin
Last Name: Hull
Post by Darin Hull » Sun Sep 13, 2020 5:34 pm
Barry,
I inferred from Keith’s comment the b means the body was made by Beaudette.
Darin
Post by Wayne Sheldon » Sun Sep 13, 2020 9:28 pm
Ford themselves did not build the bodies for their cars during the brass era. Pre-model T and first two years of model T, Wilson was one of if not the largest supplier of bodies to Ford. Wilson also supplied bodies to several other automobile manufacturers including Cadillac. By 1913, Beaudette was supplying more bodies for Ford's huge and growing demand, and remained one of if not the largest suppliers until the end of the brass era. There were about five other companies that built significant numbers of bodies for Ford during the brass era.
Ford began building bodies in house about 1917 or '18. However outside suppliers continued building some of the bodies clear though the end of model T production. The '24 coupe I used to have had a Fischer body.
Darin Hull
First Name: Darin
Last Name: Hull
Post by Darin Hull » Sun Sep 13, 2020 11:46 pm
Wayne,
Solid quick history lesson. Thank you!
